SDA SRS cabinets differences
13»
    F1nut Posts: 52,061
    Polk said that one of the design goals going from the SRS to the SRS 1.2 was the reduction of cabinet resonance (the 1.2 and 1.2TL cabinets are identical). This was achieved with a denser, more rigid cabinet material with internal grooving to break up standing waves.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited May 2023
    gregmoyers wrote: »
    The grooves must be there for something and cabinet tuning makes the most sense. What else could it possibly be for.
    Schurkey wrote: »
    I expect the goal was cabinet tuning. Standing waves doesn't make any sense to me.
    Inducing deliberate cabinet deflection/resonance is my best guess. Not only is the passive radiator vibrating to the pressure nodes in the cabinet, the cabinet walls have intentional rigidity-reducing slices carved into it to promote (controlled) panel vibration.
    But I wasn't there when the design was being debated. I have no "inside" information.
    Fifth generation SDA SRSs used a more rigid "monocoque" cabinet design with a minimum of internal bracing. Accordingly, I would not think the grooves are there to reduce rigidity.
    Schurkey wrote: »
    The grooves broke up standing waves within the cabinet.
    By what mechanism do lil' grooves break up standing waves? They're not deep enough to have any real effect based on wavelength.
    I don't have any inside information either, but I do know that one of the ways of reducing standing waves is asymmetrical and uneven surfaces. The grooved surfaces on the sides and bottoms of 5th generation SRS cabinets probably act like grooved acoustical panels to scatter sound.
    pitdogg2 Posts: 27,447
    That was my take as well.
    Whether it was marketing fluff or not I would have thought there was some science to it.
  • skipshot12
    skipshot12 Posts: 2,094
    I thought the best way to prevent waves inside a speaker cabinet was to eliminate right angle corners.
  • gregmoyers
    gregmoyers Posts: 141
    Whatever the exact intent and the reasoning behind the grooves was, there they are and the speakers sound incredible. I think all comments here make good sense and the one fact in all of it is that Polk said they were trying to break up standing waves and reduce cabinet resonance. So they used denser material with specific groves cut in specific places, eliminated a maze of bracing and called it good to go.
  • gregmoyers
    All this being said, should I put BH5 in my SRS cabinets? I have not yet and am looking for someone who has and is it an improvement at all?
    F1nut Posts: 52,061
    gregmoyers wrote: »
    Absolutely, but only 3 or 4 inch wide strips behind the mid-drivers.
  • gregmoyers
    I will dynomat the drivers when I have them out. Did the PR a while ago but was too lazy to take the drivers out.
    nooshinjohn Posts: 26,023
    gregmoyers wrote: »
    Very nice.
    I love my wood. Don’t we all??
    Morning wood can be especially pleasing…
