RT3000P Crossover
I picked up a pair of these speakers last month that had the crossovers redone. Previous owner replaced stuff and just put back in cabinet with loose parts. They wanted to come back and mount everything to a new board but never did. I would like to mount everything to a piece of 1/2” MDF. I removed the crossovers tonight. I have the diagram for the crossover but still not 100% sure how to do it. Last crossover I did only had to replace one capacitor so fit back on original board. Previous owner said spent $200 per crossover. Didn’t look up prices gdvabtblwyi7.jpeg
but does look like quality parts.
    pitdogg2 Posts: 27,352
    That's some terrible looking work, no offense intended.
  • Polk_Denon
    Polk_Denon Posts: 27
    edited April 2023
    Yeah it does look like crap. That was how the previous owner did it, that’s why I want to put everything on a new board. The one cross coil fell off the board when took it out of the cabinet
    F1nut Posts: 52,012
    Good Lord, what a mess.
    VR3 Posts: 29,554
    If you simply want to secure everything, remove it all and secure it to a mdf board and reinstall.if you want it to look like someone professionally assembled it? Deaolder everything and start over.
    VR3 Posts: 29,554
    The biggest problem I see is that there is no way those coils are a dcr match. This would change the voicing of the speaker tremendously, good or bad
    VR3 wrote: »
    I seriously was thinking the same thing.
  • VR3 wrote: »
    That’s the plan. Never did a crossover before so even looking at the schematic, not sure how to lay all the parts out on the mdf board
  • It's not that difficult to have custom circuit boards made that can actually fit the components made. You need to have the original schematic and the dimensions of the coils, resistors and capacitors. I can help if you want to do it the correct way.
    I’d appreciate the help. Never did a crossover before so not sure on how to lay the parts out on a piece of mdf board.I have the schematic for these
    F1nut Posts: 52,012
    One huge problem you have is none of those inductors are correct. As previously noted, the DCR specs are way off.
  • F1nut wrote: »
    If any of the parts are not correct, I will get the right stuff. Going to remove all the parts, hopefully tonight. Previous owner said his friend knew a lot about crossovers and he helped him with the parts but guess he didn’t know lol
    edited April 2023
    Rather than trying to place everything on a piece of wood I would suggest having a printed circuit board made that would have all of the holes pre-drilled and plenty of space for each component. They can be made with the part number and line drawing of where each part is placed on the board. It might cost between $100.00 and $200.00 for the printed circuit board (called: PCB) file to be created (educated guess). And less than $50.00 to have 10 made.
    ummmm @gimpod had all kinds of trouble on his last go around for boards to get his correct....they were far more than that afaik
    Post edited by pitdogg2 on
    VR3 Posts: 29,554
    Point to point is the way to go, IMO.
    As far as the inductors go... you can go to a lower DCR but it will change the sound. if you like the way they sound now... then... hey keep them and save the money. The parts quality is not in question
  • VR3 wrote: »
    Last night I hooked one up and compared it to another rt3000p I have that has the factory crossover parts yet. Sounded similar to me but then just had both sitting on workbench. Few months ago I had the ones hooked up in the living room that has factory crossovers yet, amps are bad in lower cabinets but thought the uppers sounds very good.
  • Ok got all the stuff removed from the board except the 2 blue caps. Here is everything….
    F1nut Posts: 52,012
    Multicaps are SO yesteryear...yuck.
  • Polk_Denon
    edited April 2023
    What do you recommend?
    What is the cross coil? What did it replace on the schematic?
  • bcwsrt
    bcwsrt Posts: 2,520
    From the 0.2 mH value, would appear to be the tweeter coil.
    Brian
    Polk_Denon wrote: »
    It appears L1 in the tweeter circuit.
    Notice how that .2mh is .3 ohm.
  • Polk_Denon
    edited April 2023
    Polk_Denon wrote: »
    So it’s the wrong part compared to the original used from Polk?
    Looks like the red 3.0 coil is correct for the mids? Also the Mills 1 ohm resisters. Looks like is 2 on the mids but the resister on tweeter is 1.5 ohm. Am I looking at that correct?
    F1nut Posts: 52,012
    edited April 2023
    The inductor mH values appear correct, but the DC resistance (DCR) values are way off. All should be replaced with the correct values per the schematic.
    For the 3 and 9uF look at Sonicap Gen I or Clarity CSA. For the others due to the high values you'll likely have to stick with electrolytic caps.
    The resistor values are correct, you don't need to replace them.
  • F1nut wrote: »
    Will take a look at those 3 and 9uf. What about the inductors?
    So it’s ok to use the mills 1 ohm resistor on the tweeter even though the schematic is a 1.5 ohm?
    F1nut Posts: 52,012
    I'm sorry, I thought you said you had a 1.5 ohm resistor already for the tweeter. If not, then yes it needs to be replaced with the correct value.
    For the inductors you will need to search online for ones that match the original values.
  • F1nut wrote: »
    Will get a 1.5 ohm resister then. Looks like $10 from PE. What brands of inductors you recommend? Looked briefly on parts express from my phone but will have to search again when on the PC
    F1nut Posts: 52,012
    Whatever brand has the exact values required.
  • Polk_Denon
    edited April 2023
    Was looking on PE at the inductors table and noticed solid core and air core. Does it matter which type use for the tweeter or mids?
    I did find a match for the one inductor on the mid(L3) 1.0MH DCR 0.3 ohm. Haven't found an exact match yet for the 0.2mh dcr 0.3 ohm or the 3.0mh dcr 1.25 ohm
    F1nut Posts: 52,012
    Air core is better.
  • Besides Parts Express, where are some other places to get inductors? They don’t have an exact match for the 0.2mh or 3.0mh
    VR3 Posts: 29,554
    Hifi collective
  • Polk_Denon
    edited April 2023
    VR3 wrote: »
    Hifi collective
    no luck on that site either. When looking at the complete list on Parts Express I did see a .2mh dcr .29 On the schematic it's .2mh dcr .3 Would that work? Rated at 200 watts rms. How important is the wattage rating?
    With the 3.0mh I'm not seeing anything close to the 1.25 dcr on the schematic
    F1nut Posts: 52,012
    I believe you can custom order inductors from HiFi Collective and also try Parts Connexion.
