L600 Polarity Issue
I didnt see any mention of this in the manual which made it all the more confusing. I have them hooked up in reverse currently to be in phase with the other speakers/subs I have.
If the whole system sounds best to you that way I don't see an issue with running it that way for home theater. But do the main speakers sound better, worse, or no different if you just use the main speakers by themselves for music connected up that way? In most cases a manufacturer recommends connecting the speakers normally regardless of what an auto configuration microphone picks up. I'm not sure that's always the best or only advice with multiple pairs of speakers and subwoofers and trying to get them to sound the best when all working together. Only the owner can figure out what works best in their room.
Reminds me of Lone Star Audio Fest...
Every once in awhile there would be a victim. Russ or I would reverse the phase on one of someone's speakers while they were out of the room.
I asked Scott Orth (Polk speaker engineer) for information:
"Hi Ken,
Audyssey has trouble with many speakers regarding polarity. When I run into this problem, I check the connections to make sure everything is correct, then tell Audyssey to continue.
When checking the polarity of the individual drivers, the tweeter and mid should be in positive polarity and the woofers in negative polarity. This is required due to the crossover topology between the mid and woofer and is normal for many loudspeaker designs.
The customer can of course reverse the polarity of the input if he wants the woofers in positive polarity and the mid and tweeter in negative polarity. As far as what’s is the best way, it depends on the rest of the system. Are there other speakers? Are they using a sub? Are they high passing the L600? And so on. Can’t discuss all of the possible permutations here. I would just leave them as is. If they are using Audyssey, it will work out the best relationship between the L600s and the rest of the system.
Scott" -
Very informative and not surprising. Love a good technical answer from a Pro!2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Very helpful info. I think the point of the story here is I need to ditch my off brand surrounds and center and having them all in phase is a lot easier haha.
Big shout-out to @SeleniumFalcon for doing the right thing and pulling down a bunch of cogent (and accurate) information.
... oh, and let's just pretend I never responded to this thread earlier, OK?
Having five L600s would be cool.
NM, I re-read Scott's answer from Ken and the bulb went off....
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
