Building custom component stands/platforms, need some assist with feet/cones
Joey_V
Joey_V Posts: 8,603
edited November 2021 in 2 Channel Audio
So I'm trying to finally get some components off the floor and I would like to match a new pair of Walnut speakers I am getting for the main room. Mainly I was thinking for building an isolation stand to get the Boulder (24"x34" for example) and perhaps the 2 JL subs off the floor. Also was thinking of getting the JL CR1 which sit next to the subs also off the floor.
I have sources a woodsmith/carpenter to do the platforms. We will do 3" baltic birch ply with a a walnut veneer on top for the subs and components, we will do 4" baltic birch ply with a walnut veneer for the amplifier. In addition I would like to build 2 more stands for future amplifiers (either Parasound JC1 or Mcintosh 601/611 monoblocks, @22x26" each). In addition to even that, I'm also thinking of building specialized greyed out versions, 2" for my rack to house the dac, pre, etc (7 of them @ 18"x20").
I've included some pics of the rough appearance (don't worry, they will be single color birch ply along the lateral borders, there will not be any dark ply between sheets (if you understand what I mean).
Gonna have them clear coat it as well.
But yes, my question is with regards to the feet. I'm not really in the mood to spend >$50 per foot from mapleshade (for deepcarpet brass spikes) x4 (per component stand) x 12 component platforms would = a ton of money. I would need the feet to be some formidable construction cone, with an M8 or variant machined screw up top to fit into the sunken screw attachment at the bottom of the platform. I have searched ebay, amazon, google for any decent brass footers or steel... but have come up without a good choice.
Ideally, the feet would be like these used (you can see it through and through in some):
(Another person who makes birch component stands and even puts a top carbonfiber layer - only problem is the cost is significantly more)....
I know some here are metal specialists - is there any way to machine special cones for these component stands that arent mass market like those on Parts Express?
Post edited by Joey_V on
  • TEAforONE
    TEAforONE Posts: 1,070
    https://www.usaudiomart.com/details/649742621-isolation-cones-speaker-feet-component-feet-versatile-effective-read-more/
    Absolutely no affiliation. This guy has been selling these for awhile. They look very well made.
  • Joey_V
    Joey_V Posts: 8,603
    TEAforONE wrote: »
    I saw that and contacted him
    He’s very slow to respond but he does
    I see some scratches in those pics and was wondering why they’re only $6 a piece, like would they be able to hold up a significant component
  • I think what you have in mind is going to be beautiful and stable. It always makes me grit my teeth a little when people refer to spikes as isolation devices though. They couple and add stability. Those lightweight spikes the guy is selling are probably aluminum and definitely not what you want to use for a spike in my opinion. Hard steel would be best. I made mine out of Grade 8 bolts ground to a point.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Joey_V
    Joey_V Posts: 8,603
    Can you show me pics?
    I’ll pay you for the spikes
    Exactly what I was thinking though. To hold up the amp and the 4” birch... you’re looking at a lot of weight
  • Joey_V
    Joey_V Posts: 8,603
    Ideally I want it to bolt above and sandwich the platform.
    But because of the # of stands, I really don’t want to buy a bunch of SRA units because that’s gonna cost the same as a car
  • Joey_V wrote: »
    The ones I made have absolutely no bling factor at all.....zero....zilch....nada. I just cut the head off of a 1/4-28 Grade 8 bolt, chucked it up into a high speed drill and held it to my bench grinder. They come out pretty well centered but not perfect. Mine are bearing on a concrete block as part of my DIY vibration isolation subwoofer platforms.
    You could get a machinist to drill and tap your bling ones of choice and the Grade 8 sharpened tips could be inserted in the ends. What they bear upon should preferably also be a very hard steel.
    Or you could settle for plain old stainless steel. Not as good in my opinion but much harder than brass or aluminum, and polishes up nicely for that bling factor.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,944
    You want brass or stainless steel. A decent machine shop can make whatever you want. A good part of the cost is the CAD drawing time.
    Look at the Adona multi-element spikes. Look at their racks and stands too, they are very nice.
  • Joey_V
    Joey_V Posts: 8,603
    This guy is asking $600 for 4 spikes. This is my ideal spike... but come on man...
    Joey_V wrote: »
  • Joey_V
    Joey_V Posts: 8,603
    I’ll check out adona
    Thx Jesse
  • Joey_V
    Joey_V Posts: 8,603
    @F1nut
    Are those multielement good? Are the brass spikes same as Dayton?
    http://www.adonacorporation.com/tweaks.html
  • Joey_V
    Joey_V Posts: 8,603
    I am kinda liking these
    Stainless steel
    Has a rod
    I can maybe extend it to sandwich the platform with a longer m8 rod?
    pitdogg2 Posts: 27,230
    Joey_V wrote: »
    Joey_V wrote: »
    Joey you kill me🤣🤣🤣
    You spend thousands and thousands of dollars on gear YET you cheap mucker, whine about a few hundred dollars....
    My .02
  • Joey_V
    Joey_V Posts: 8,603
    Joey_V wrote: »
    Joey_V wrote: »
    Joey you kill me🤣🤣🤣
    My .02
    $600 x 6 (6 platforms). I can see 1 set. But 6 is a lot.
    That’s ridiculous for spikes. It’s made of steel only, there’s not even any still point or any other tech involved.
    We aren’t even talking about the cost for the super thick platforms.
    F1nut Posts: 51,944
    Joey_V wrote: »
    @F1nut
    They are excellent and nothing like Dayton. The Adona multi-element spikes are brass tipped with a Kevlar composite for the rest. I have a set here.
    Edit: if you're asking about those other spikes on their site, yes they are the same as Dayton.
    F1nut Posts: 51,944
    Joey_V wrote: »
    I had a local machine shop quote me $600.00 for 8 stainless steel spikes. The main part of the cost was the CAD time. I passed.
    Those are very nice platforms.
  • Joey_V
    Joey_V Posts: 8,603
    Agreed. 4” of birch, I believe that’s a 5 stack. I wanted a walnut top veneer so that’s what they prototyped as they never built anything with my specs and thickness.
    I have made contact with a builder who sources panzerholtz... more costly but I want to see what they can come up with.
    An sra stand will cost Atleast $3,000-4000 for the amp alone... I think I can build my entire set for that much. That’s 6 big 3 or 4” stands and 7 medium 2-3” component stands to buffer the components on the SRA Scuttle rack I have.
    This below is panzer in 24x34” which is the amp alone
  • Joey_V
    Joey_V Posts: 8,603
    I think panzer is nicer than regular birch ply... but it’s gonna be about double the price. I know it’s used in high end turntables by clear audio so there’s probably some benefit. Not sure how much more it weighs over same size birch.
  • Joey_V
    Joey_V Posts: 8,603
    Joey_V wrote: »
    @F1nut
    Jesse
    What do you about these 316L steel ones? I can have the builder custom length the m10 rod so that it screws through the entire platform on 4 corners.
    F1nut Posts: 51,944
    316L stainless steel is slightly more resistant to corrosion, which is not a concern for your purpose. Either 316 or 316L would make for excellent spikes, IMO.
    F1nut Posts: 51,944
    Joey, since you need to pierce thick carpet you might ask if the seller can make the tip a sharp point. The ones in your pics appear slightly rounded.
  • Joey_V
    Joey_V Posts: 8,603
    The seller for the panzer sent me side by side pics
    Personally I think he chose a very subpar example of birch ply
  • Joey_V
    Joey_V Posts: 8,603
    Good eye Jesse
    F1nut Posts: 51,944
    Joey_V wrote: »
    Yeah, that's crappy plywood. This is baltic birch plywood.
  • Joey_V
    Joey_V Posts: 8,603
    Joey_V wrote: »
    I don’t like it when sellers try to trick the buyer. That’s what I thought too Jesse
    F1nut Posts: 51,944
    I had to look up this panzer material. It's full name is Panzerholz. A plywood material made under extreme pressure, which is so dense it sinks in water. It also happens to be bullet proof and was used by the Germans on tanks. Must weigh a ton!
    Joey, you might find this interesting.
    https://www.lessloss.com/page.html?id=80
    I should add that results are not surprising. Any wood or wood product will not resonate like metal will.
    txcoastal1 Posts: 13,519
    When you search under marine grade plywood...you'll find different grades up to 1-1/8" think
    You can double layer to desired thickness.
    Keep in mind the escalated cost for the panzer is the labor and blades to cut it
    https://www.google.com/search?q=marine+grade+plywood&rlz=1C1CHBF_enUS967US967&sxsrf=AOaemvLfYbwfssYYIeL56ns8kB22BhLbpg:1636416328875&source=lnms&tbm=isch&sa=X&ved=2ahUKEwirpvLv_Yn0AhXUlWoFHYmSDPEQ_AUoAnoECAIQBA&biw=1436&bih=668&dpr=1.34#imgrc=ivgnV189o91QTM
  • Joey_V
    Joey_V Posts: 8,603
    Clear audio makes it for their statement products... it’s very cool
    My SRA rack uses birch but not panzer
    The guy who builds the panzer will text me a mock up of a rack he designed, I’ll see how good he really is. Otherwise I’ll stick with the Baltic platforms that I designed.
    A 4” stack should be enough to hold any product
  • Joey_V
    Joey_V Posts: 8,603
    txcoastal1 wrote: »
    I don’t know how workable a slab of panzer is going to be.... if this guy will just supply it, the problems of drilling into it or rounding it off is going to be a pain
    And the question really is: am I going to hear a difference over a 4” Baltic ply platform?
    I don’t think I can hear that well
  • I think it's about lots of small incremental improvements, which may be subtle on an individual basis, but when you add them up you get a huge not so subtle improvement. But you're just not going to get that without going through the process.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
