Advice on repairing SL1000 tweeter
shnaggletooth
Picked up a pair of Monitor 7C speakers today. These have SL1000 tweeters, not the SL2000 tweeters, and the Polk badge is directly on the front bottom of the wood cabinet, not on the grill itself.
Anyway, one of the tweeters is less bright than the other. Examined it, and the clear plastic half-spherical covering has come about halfway undone the main perimeter. The black fabric-y portion underneath it floats "loose" with the cover not securing it tightly.
Not sure if that is any cause of the slight dullness, but assuming it has to be repaired anyway -- what is best to seal the covering -- rubber cement, Elmer's? Does is really matter?
Toothpick to illustrate how the plastic cover has come undone:
Not worth repairing...
shnaggletooth wrote: »Picked up a pair of Monitor 7C speakers today. These have SL1000 tweeters, not the SL2000 tweeters, and the Polk badge is directly on the front bottom of the wood cabinet, not on the grill itself.
Not worth repairing and besides, it's a horrible sounding tweeter. Buy two of these, you'll thank me. https://reconingspeakers.com/product/polk-sl1000-sl2000-tweeter/
One thing, you'll have to slightly modify the opening on the bezel to make it fit. -
I know it isn't your question but are you sure they are 7C and not late model 7B? I had *thought* that the 7C marked the change to the SL2000 tweeters. Late model 7B went from Peerless to SL1000 and they did have the grill not extending all the way to the bottom with the badge on the enclosure as you say. Did your speakers originally have the SL2000's?
I've never understood how, apparently the SL1000 tweeter was Polk's attempt at making a better Peerless, and how when they made the switch in the 7B they saw no need to modify the crossover networks, yet people say that the RD0194 is a replacement for the SL1000 but not the Peerless. There is also the issue of how the SL1000 mounting holes and bezel size are the same as the Peerless but not the SL2000. There were some SL1000 that were purported to be NOS on eBay but I don't know if they are still there. Everybody seems to say they are harsh sounding. I haven't heard them; only Peerless.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »I know it isn't your question but are you sure they are 7C and not late model 7B? I had *thought* that the 7C marked the change to the SL2000 tweeters. Late model 7B went from Peerless to SL1000 and they did have the grill not extending all the way to the bottom with the badge on the enclosure as you say. Did your speakers originally have the SL2000's?
They're 7C's, according to the labels on the back. Picked them up in Weehawkin for $50 yesterday, curbside, but I messed up yet another Polk buy -- didn't at least take the grills off to examine the drivers, as one of the midwoofers turned out to be a non-Polk (Pyle driver) that had no surround. There was some excuse for my carelessless -- Weehawkin traffic police van was making it's way up the street and I was double-parked, so I had to get out of there. Still, I should have had the seller send me pics of all the drivers before the sale. Fortunately, I have a midwoofer available from an earlier 5 Jr+ goof-up which needs an SL2500 to complete (and if anyone here has a good, working SL2500 tweeter available for a reasonable price, PM me
I think Polk back in the day was probably pretty sloppy with standardizing their Monitor and SDA releases across the entire spectrum. So the majority of 7C's might have SL2000's, but a significant minority being released were for some unknown reason equipped with SL1000's. Meanwhile, a majority of 7C cabinets had the Polk logo on the grills, but others (like mine) used the 7B cabinets, etc. I'm not even sure what impedance these speakers are because there's no mention of it on the rear, and there's no solid info on the Web. There's more reliable info and more back-in-the-day official literature for 60's AR speakers and other manufacturers than there is for late 70's-1980's Polk speakers.
Anyway, how to safely seal up this plastic half-dome for the tweeter...? -
Not worth repairing...shnaggletooth wrote: »Picked up a pair of Monitor 7C speakers today. These have SL1000 tweeters, not the SL2000 tweeters, and the Polk badge is directly on the front bottom of the wood cabinet, not on the grill itself.
I wouldn't ask the question for someone just to respond that it's not worth repairing. I was hoping for actual advice on sealing up the plastic half-dome.
F1 Nut: I know your standard response for these questions is to tell people to open up their wallets and buy the latest Polk R-something-or-the-other tweeter replacement, but that's not possible for everyone. -
They are 7C's. Polk apparently was sloppy back in the day standardizing their releases. -
That is pretty strange. I'd be SUPER interested in knowing what else is inside your speakers. MW# and crossover components. I'm also confused surprised by that construction of an outer clear plastic dome over an inner darker material one with a significant air gap between. Are you sure that black stuff isn't the wool on the pole piece that was used for some absorption of back wave? I would think that one dome would be the key. I think the other stuff isn't moving but is fixed to the pole piece. What adhesive to use? I really would be just guessing but perhaps Ayleens Tacky Glue. Maybe Super Glue Gel? Gotta be very careful not to get any into the voice coil gap.George / NJ
iFi nano iDSD DAC
iPurifier3
Let me put it another way, NO REPAIR POSSIBLE.
@blinkbears has a set of 7C's with SL1000's he says. Are they able to take the 198's with the 8uf caps across the resistors like the last revision for SL2500 shows?
(The 198 domes and/or magnets can be adapted to the SL1000 metal plates)Don't take experimental gene therapies from known eugenicists. -
Can confirm my 7Cs have the SL1000 along with the MW6502. Main reason I chose them is they are a visual match with my Monitor 10A with the SL1000 and the MW6503 . In my very short time here on the forums I have learned that perhaps these tweeters are not the most ideal revisions haha.
Westmassguy did the TL mod to a pair of 7C with the SL2000. I wonder if the crossover was tweaked when Polk went from the early 7C with the SL1000 to the later one with the SL2000.
https://forum.polkaudio.com/discussion/192120/monitor-7-with-tl-upgrade#latestGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Having dissected both SL1000 and SL2000, I always assumed Polk added a few more turns on the 2K coil to tame the peak due to changing to the plastic bezel.
The way shnaggletooth described his 7Cs in this thread are exactly the way the 7Cs I bought a couple weekends ago are.
