Polk L800 amplifier
13»
    VR3 Posts: 29,731
    I'm thinking 19 ft
    heiney9 Posts: 25,672
    So, for me it really comes down to which I want in my system more since the amp I've settled on is this. It appears it won't play nice with the L800's.
    It's a real conundrum as I want the L800's but will most likely have to settle for the L700's because of amp choice and I really don't think I have the room to fully explore what the L800's are truly capable of.
    pitdogg2 Posts: 27,886
    heiney9 wrote: »
    Why not?
    heiney9 wrote: »
    Why not?
    Maybe it will now that I reread the home theater hi fi review. It's single ended so I'm thinking it might work. https://hometheaterhifi-com.cdn.ampproject.org/v/s/hometheaterhifi.com/reviews/amplifier/integrated-amplifiers/pass-labs-int-25-integrated-amplifier-review/amp/?amp_gsa=1&amp_js_v=a9&usqp=mq331AQKKAFQArABIIACAw==#amp_tf=From %1$s&aoh=16553037762613&referrer=https://www.google.com&ampshare=https://hometheaterhifi.com/reviews/amplifier/integrated-amplifiers/pass-labs-int-25-integrated-amplifier-review/
    edited June 2022
    Dual differential balanced IIRC is the topology that will not play nice.
    That one should work.
    Thanks Ivan. I am so used to modern Pass amps not being compatible with SDA unless one has the dreadnought, so I didn't look that closely. Still doesn't solve my problem of not having enough space to properly set up the L800. Only thing that will solve that is moving...lol
