Silver interconnects
if you wondered about silver cables in your system but always heard they were harsh and bright, take a look at these.
https://www.thesoundadvocate.com/2021/04/hapa-audio-analog-interconnects-quiescence-s-and-breathe-s/
Puritan PSM156
  • Emlyn
    Emlyn Posts: 4,920
    I've owned some high end speaker cables before that had a hybrid of fine gauge copper and silver for the top of the biwire and larger gauge copper for the low end.
    I have a few sets of Kimber Hero and Kimber Silver Streak interconnects around that I only use once in a while. They sound roughly similar to me. I wouldn't call the Silver Streak cables bright although their sound is a bit more "open" than other cables I have. They were good on Polk LSi15s that had a fairly recessed top end.
    audioluvr Posts: 6,079
    Snake oil I tell ya!
    F1nut Posts: 52,406
    I use silver phono cables in one rig and silver umbilical cords in another. Not bright at all.
    txcoastal1 Posts: 13,520
    I have a couple pair of silvers, been awahile since they were in use since I have broke down my rigs. In mt systems they worked best a source IC's VS from pre to amp IC's
    The price on these seem reasonable compared to good name brand silver / OCC IC's The softening of lower registers could have to do with the super fine litz wire they are using.
  • marvda1
    marvda1 Posts: 4,972
    audioluvr wrote: »
    when i was writing the review he came out the copper versions, they're on their way so i will see if copper makes the difference.
    Puritan PSM156
  • Buzzfuzzwuzz
    There's very little difference and tons of projection when it comes to the material used for speaker cables. Distance and gauge have more impact.
  • marvda1
    these are interconnects.
    Puritan PSM156
    F1nut Posts: 52,406
    Ummmm.....NO!
  • mantis
    mantis Posts: 17,691
    It's just physics. Silver is a better electrical conductor than Copper or Nickel which is what is common in most interconnects. If your buying Interconnects and thy are bright, than you have a crappy pair of interconnects that are possibly voiced by whoever made them.
    Silver cables are not bright.
    Dan
  • Emlyn
    Emlyn Posts: 4,920
    I remember now that the Kimber Silver Streaks have two copper conductors and one silver. They use the same WBT RCA connectors, so there's really not much difference between them and the Hero RCA cables. Other than price and the Silver Streaks don't use techflex.
  • Buzzfuzzwuzz
    Ummmm.....NO!
    Good point
  • Gardenstater
    Gardenstater Posts: 4,990
    edited April 2021
    I think the purity of the material, ie. lack of grain structures is the most important. Overall resistance/impedance is important (mainly speaker cables) but less so. Why don't they make audiophile cables out of aluminum, which has a pretty high conductivity? Rhetorical question/food for thought. I think Silver is available in UPOCC (Ultra Pure Ohno Continuous Cast) too, not just copper.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • marvda1
    JPS labs does use an aluminum, alloy in it's cables.
    Puritan PSM156
  • pearsall001
    pearsall001 Posts: 5,400
    Check out Grover Huffman Cables
    http://www.groverhuffman.com/
  • invalid
    invalid Posts: 1,560
    It would seem to me that aluminum would be more difficult to solder than copper, although one could use mechanical means to attach the connectors. I know aluminum was a poor choice in residential wiring because of creep, which shouldn't be a problem with low current interconnect cables.
    pitdogg2 Posts: 27,914
    Creep?
    Is that in reference to ohms and resistance?
  • invalid
    Creep?
    No, aluminum expands and contracts more than copper when current going through it heats it up cause the mechanical fasteners to loosen over time. There were several house fires because of this when aluminum wire was allowed in residential construction.
  • Gardenstater
    And the aluminum oxide has greater resistance causing more heat. That was a bad combination leading to arcing I believe.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    invalid wrote: »
    Creep?
    I remember that. I was actually working at a Furrows building materials in the mid 80's. For some unknown reason I always thought that it had something to do with the resistance, the resistance was building up after so many heat and cold cycles like you said and that caused fires. I remember having to point people to the proper outlets and switches and things like that because not all of them were copper and aluminum approved.
  • GlennDog
    GlennDog Posts: 3,158
    Yesterday I was a in a house where all the breakers were rated at 20 amp
    half were connected to CU and 1/2 to AL
    The aluminum wire was 12 AWG & the CU wire was 14 AWG (all 15 amp circuits)
    I hope they don't miss a Home Owners Insurance payment!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    I'm looking to replace my MIT Shotguns and WW cables.
    Marvin,
    I just got wind of this company. Jason Wong was so graciosos to extend his 20% Holiday discount another couple of days
    So, I was wondering if it would be a step up Or a lateral move to go with Quiescence Silver (replacing MIT Shotgun S1) and adding the Aero USB (replacing the WW platinum Silver)
    Thanks in advance
    Happy New Year!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    F1nut Posts: 52,406
    edited December 2021
    Are you nuts!?!
    Dibs on the Shotguns.
  • marvda1
    GlennDog wrote: »
    Marvin,
    Thanks in advance
    Give them a try, he has areturn policy. besides no one cable(mit) wotks in all systems and to everyone's taste.
    if want a warmer sound try his copper cables.
    Happy New Year!
    Puritan PSM156
  • kevhed72
    kevhed72 Posts: 5,245
    GlennDog wrote: »
    Marvin,
    Thanks in advance
    Happy New Year!
    I would also be interested in your MITs if you decide to sell....looking to upgrade to all Shotgun S1. Thanks
  • GlennDog
    Decided to wait for some ICs to pop up on the used mkt
    But I am gonna spring for the Aer0 USB
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    Are you nuts!?!
    Boy, I'd have to agree here. Only dibs on the WW silver platinums! :D
