Parasound 1200mk2 issues
seabeerob213
seabeerob213 Posts: 1,843
edited October 2020 in 2 Channel Audio
I've noticed, that when it isn't warmed up, my amp will feed weak or no signal intermittently to the 2 channels. Once it's been on and running a while, this is a non issue, but for 20 or so minutes, it's incredibly irritating. Is this a known issue? I've tried 3 different sets of ICs, 2 sets of speaker cable, and get the same result. When I leave it on 24/7 it's a non issue, but when my power bill went through the roof, it went to being switched off when I'm not using it. Could I have a loose internal connection, that when warmed up, expands enough to not be loose anymore? Is this potentially dangerous to my amp or speakers? Running toslink from tv to an HK3490, and RCA to headphone cable to it as well to play off my phone. Currently using some BJC interconnects, analysis oval speaker cables, a pangea power cord, and an apc surge protector. Have the volume knobs for each channel set at halfway. Amp is set to stereo and not mono.
  • Nightfall
    Nightfall Posts: 10,083
    Off topic, but can you quantify through the roof? How much does an amplifier cost to keep on 24/7?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • seabeerob213
    Before I was paying about 150-200 euro every other month, same time frame I set up my stereo, it went to 460 over 2 months.
  • seabeerob213
    I'm not sure it's solely from the stereo, several neighbors all said their bills were extremely high in the same 2 months, maybe they raised our rates without informing us.
  • seabeerob213
    @KennethSwauger can you move this thread, I posted in the wrong subtopic.
  • Sure, what category should I move it to?
  • seabeerob213
    2 channel or electronics
  • seabeerob213
    Thanks ken
  • JayCee
    JayCee Posts: 1,509
    I've noticed, that when it isn't warmed up, my amp will feed weak or no signal intermittently to the 2 channels. Once it's been on and running a while, this is a non issue, but for 20 or so minutes, it's incredibly irritating. ...Have the volume knobs for each channel set at halfway.
    Similar design to my 1500A's. I'd say it's worth popping the hood and taking a look for bulging caps, heat damage or anything obvious. Do you run it @ 220V or off a transformer?
    I set mine up for 220 when I was in Germany. Not sure how Italy is for Parasound expertise but I had little luck finding anyone familiar in the Ramstein area. I reached out to Parasound re. fuse values before I did the conversion and Richard Schram, Parasound President, replied on a Sunday. Might be worth running your initial symptoms by them and asking for advice. service@parasound.com
    Nothing to do with your symptoms but I've always run the gain pots at full. I did have one that was scratchy and was able to clear it up by turning back and forth several times to self clean.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Does this model have a protection relay for the speaker outputs that clicks a few seconds after power-on? If so I've seen those get oxidized cause signal drop, low level output, or distortion at initial power-on or with low level signal.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • JayCee
    JayCee Posts: 1,509
    Yes, good suggestion.
  • seabeerob213
    JayCee wrote: »
    I'll try that and that email, earlier it was.cutto g my right channel out even when we'll warmed up. The volume was way down but was still playing. Pushing on the cone for it to play fine again, so maybe the issue Is with my speaker?
    pitdogg2 Posts: 27,540
    Find some different speakers and give them a try
  • seabeerob213
    I'll have to. Unfortunately, my 5As and 7s both need a new driver, but I may have some cheapo bookies sitting around somewhere. I may just switch left and right and see if the problem follows the speaker.
  • seabeerob213
    I did have a similar issue a few years back when I was using this set up in the barracks, https://forum.polkaudio.com/discussion/171387/amp-has-static-and-audio-loss#latest
    Even posted about it, thought it was due to a seized driver in my 5A. While that was and is an issue, it currently isn't the cause as I'm using my 5jrs. I may give just the 3490 a spin on them to see if the issue persists when the amp is removed from the equation.
  • soundfreak1
    soundfreak1 Posts: 3,414
    The output relays on the 1200/ll both are known issues. Sounds like mine was. Replaced relays, fixed. Back than (10 yrs ago they were 75. Ea from parasound.)
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • soundfreak1
    BTW a recap is in line by now. Did mine and it was wonderful.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • seabeerob213
    Any walkthroughs you know of for either of these fix/upgrades? I've never really got into soldering on something like this. I tried to fix an alpine car amp, but I couldn't find the issue. Replaced the same blown mosfet 4 times, and it wouldn't last longer than putting the negative cable back on the battery.
  • soundfreak1
    I'm not a tech myself, my best friend is a fully certified Parasound factory tech and was a warentee station for 40 years and still is. He contacted parasound on mine and got the parts. Easy work according to him.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • CH46E
    CH46E Posts: 3,595
    edited October 2020
    I just had this same issue. Technician cleaned the relay contacts and its golden. Cost less then $50.00. Oh and he added pressure/tightened them up for better contact.
  • soundfreak1
    Did that first also....it will happen again...what year was it made? It is a known issue with them,just make it easy on your self and replace them.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • seabeerob213
    Good news? I tested it with my schiit dac and it works fine. The 3490 has the left channel cutting out when used as a stereo receiver. I ran powered studio monitors and the left channel cuts out. I wiggle the RCA at the preout and it works perfectly when I find the right spot. Now I gotta figure out how to fix it, and I guess I'll use the attenuated tape out rca with the monitors for now.
  • seabeerob213
    I dont see anything immediately wrong, and the solder joints under seem good to, so it must be internal to the jack itself.km6rx5xi3flb.jpg
  • skrol
    skrol Posts: 3,476
    I was going to suggest cracked solder joints. I have an HCA-1000A that suffered from this on the bias resistors. Might give the bottom of the board a very good look over and reflow any that look suspect.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol wrote: »
    its the HK 3490 thats bad, not the parasound
  • skrol
    skrol Posts: 3,476
    Parasound wouldn't be the only one I've seen cracked solder joints. I got a Denon DRA-825R cheap because it had a few cracked joints at the RCA connectors. Some RCA's hold pretty tight and people wiggle and tug on them pretty hard. Likely all that wiggling and force tends to crack the tin/lead. Worst case, they break the RCA jacks.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol wrote: »
    The parasound is still good, it the HK3490 I was using as a dac/pre that has the bad RCA
