Do I need amp?
Gentlemen, I have recently bought a pair of rti a7, one csi4, one dsw 550 and a pair of rti a3. I have also bought a sr5014 marantz avr. Will this be enough to move the whole set? Do I need amp for the a7s?
Best Answers
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2020 Answer ✓
    Do not get a pro amp, get an amp designed for home use. I always buy used. Parasound, B&K, rotel are good options. If you want to buy new here’s about the best deal you’ll find: https://www.audioadvisor.com/mobile/prodinfo.asp?number=PAC2125V2. Outlaw has a great 5 channel amp you might look at: https://outlawaudio.com/shop/index.php?id_product=27&rewrite=model-5000&controller=product
    Avoid emotiva, they’re too bright for the RTiA series.
    To hook up you’ll need a pair of rca cables to connect to the marantz’s r/l preouts. Those will go to the inputs are on the amp. The speaker cable for the mains will connect to the amp.
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    Answer ✓
    Ok but then, what are those connections for? I mean the "speaker in" & "speaker out" that you can see in the picture.
    In a pure two channel system, you want the subwoofer closely integrated with speakers, having the same tonal signature. The best way to insure this tonal match is to take speaker cable from your amplifier and run into your subwoofers speaker level inputs, and then out of the speaker level Outputs to your speakers. Your amplifier is powering the speakers, the sub is just passing that signal on.
    Game Room 5.1.4:
    Bedroom 2.1
Answers
    VR3 Posts: 29,516
    If you listen to music you will always need an Amp
  • rooftop59
    How big is your room? Is this mainly for music or movies? Your mains will sound better with an amp, no doubt, but depending on room size and crossover point you might be ok without one.
    But I agree with Trey that if music is important to you, you will notice a significant improvement with an amp...
    Game Room 5.1.4:
    Bedroom 2.1
  • Thanks a lot both of you. Which kind of amp should I add? And how should I connect the avr, the additional amp and the a7s?
  • Thanks a lot rooftop59!
  • Would it be possible to use the subwoofer to amplifie the floorstanding speakers? The dsw 550 has a 200 w amp. What do you think?ffiknd7jv5gs.png
    F1nut Posts: 51,912
    NO!!!
    The sub amp drives the sub, nothing else.
  • rooftop59
    That amp can pass the signal on to your amplifier, but it will not power any other speakers.
    Game Room 5.1.4:
    Bedroom 2.1
  • Ok but then, what are those connections for? I mean the "speaker in" & "speaker out" that you can see in the picture.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Those are for speaker level connections as opposed to line level type connections.
  • Thank you very much Ken and Kex!
  • [Deleted User]
    You're welcome, enjoy!
  • gp4jesus
    gp4jesus Posts: 2,019
    edited June 2020
    Welcome to Club Polk.
    yup. Unless Marantz stacks up well in the power department, after you get what you have set up, connected, sounding OK, those ‘A7s would be much happier w/a separate amp.
    I agree w/...
    rooftop59 wrote: »
    Do not get a pro amp, get an amp designed for home use. Parasound, B&K, rotel are good [used] options. If you want to buy new here’s about the best deal you’ll find: https://www.audioadvisor.com/mobile/prodinfo.asp?number=PAC2125V2. Outlaw* has a great 5 channel amp you might look at: https://outlawaudio.com/shop/index.php?id_product=27&rewrite=model-5000&controller=product
    lots of good advice above. Also Outlaw sells good mono amps at a good price.
    https://www.outlawaudio.com/products/amps.html
    You should find some* used eBay, etc
    A side note: the last couple of weeks I’ve been listening to a pair of outdoor speakers, Polk Atrium 55 powered by either a Rotel, Parasound, or Belles. Today I connected them to a Denon AVR 2802 only to realize it will “do” for my backyard system but I miss the above 😟
    Enjoy! Tony
    Psst: I have Parasounds & a Belles for sale either of which your ‘A7s would love
    *all connected w/Premiere ICs
    F1nut Posts: 51,912
    That Marantz is a nice AVR. IMO, you do NOT need a separate amp.
