Volume doesn't stay where set
When using our soundbar the volume will suddenly increase almost to max volume. After turning the volume down, it only lasts a few minutes and then the volume spontaneously increases again. It is very annoying and we are about to send it back. I'd rather try to find a solution. Thanks.
  • gimpod
    gimpod Posts: 1,793
    edited June 2020
    Welcome to Club Polk
    Keep the remote away from the dog/cat/wife or quit sitting on it. :smirk: JK
    More info needed, system specs, soundbar make & model, etc...
    Just had a thought, do you have any florescent lights (tubes or bulbs) on if so turn them off and see if it solves the problem. Sometimes when florescent lights start to go bad or the color temp can interfere with inferred receivers.
  • BlueFox
    BlueFox Posts: 15,250
    Nothing personal, but you must be the thousandth person whose first post is a Polk sound bar issue. Good luck.
    audioluvr Posts: 6,010
    Something is causing your soundbar to recognize a volume up signal. Neighbors garage door opener, a laptop, security system, aliens from another solar system. OR maybe it just likes it cranked to 11.
