PSW505 Amp failed - Polk says part on back orderggested aftermarket???
Any idea for after market source for amp board? They said the part number is RF5050-4.
Joe
  • lopezjl
    Just called still on back order.
    treitz3 Posts: 20,295
    If you remove the plate amp and send it in to a reputable repair shop, they should be able to diagnose and repair it. FWIW
  • Ruiner13
    I have two dead PSW505's, I guess I'll be taking them someplace.... now to start that search.
  • rooftop59
    rooftop59 Posts: 8,120
    Ruiner13 wrote: »
    The bench fee will be more than it's worth to repair them unfortunately...
    Game Room 5.1.4:
    Bedroom 2.1
  • Ruiner13
    Ruiner13 Posts: 16
    rooftop59 wrote: »
    Ruiner13 wrote: »
    What would you suspect it would cost in your experiences Roof?
  • rooftop59
    Ruiner13 wrote: »
    rooftop59 wrote: »
    Ruiner13 wrote: »
    Bench fees alone are usually $125-150. You might save a little with two. Depending on where you are, you can find an SVS PB 1000 for 350-400, and that will trounce both of your current subs put together. I would go in that direction.
    Game Room 5.1.4:
    Bedroom 2.1
  • mantis
    mantis Posts: 17,638
    It sucks we live in a throw away world.
    Dan
  • Ruiner13
    Ruiner13 Posts: 16
    rooftop59 wrote: »
    Ruiner13 wrote: »
    rooftop59 wrote: »
    Ruiner13 wrote: »
    Do tell brother, where are you finding that sub so cheap? I see them for 800 on amazon.
    VR3 Posts: 29,701
    mantis wrote: »
    This is the irony to the environmental movements.
