Restoration of SDA 1C Again!!!
Hi
I got a pair of SDA 1C. I would like to do a full restoration (cabinet side panel came out). I know there are lot of threads about this and I went through. I have a very good idea what to do.
I have one question regarding securing the magnet. I am planning to use Locktite Red. Should I just randomly put in three to four places along the joint of magnet or there is any preferred way to do that?
Any help would be great!
Thank you!
Polk SDA 1C and CRS+, Klipsch Forte II, Focal Chorus 706, Sansui: 9090DB, Eight Deluxe, AU-9900; Pioneer SX-1010, Marantz: 300DC, 3200B, 2325, 2275, Thorens TD-145, Technics SL-1650, Pioneer PL-707, Pioneer RT-707
    F1nut Posts: 52,038
    Use Loctite Power Grab or JB Weld. Loctite red is for screws and bolts.
  • F1nut wrote: »
    Okay, thanks!
  • Got all the Sonicaps and Vishay Mills resistors today and will get the pair of Gimpods tomorrow. Here is a pic of the transformed side panels2jrleeph170b.jpg
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Those panels look very good.
    Keep us posted about your progress.
  • One speaker cabinet is done. Third pic looks different color due to flash from different angle!
  • westmassguy
    westmassguy Posts: 6,850
    Beautiful veneer work Sanjib
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Beautiful veneer work Sanjib
    Thank you, Dave! I put the vinyl film on them.
  • westmassguy
    Sanjib_a wrote: »
    Still looks nice
    xschop Posts: 5,433
    Fooled me. Looks like real wood veneer. You did a very nice job. Let us know how you like the sound after recap.
  • Faustin
    Faustin Posts: 1,151
    That veneer project came out great.
  • Loctite, Mortite, Dynamat in one set of drivers and passive woofer done. Waiting for Dave's Gimpod!
    F1nut Posts: 52,038
    I'm sorry, the front to sides and especially the sides to top and bottom transitions are all wrong.
    pitdogg2 Posts: 27,397
    edited February 2020
    Sanjib_a wrote: »
    The gaps in the gasket on those drivers and passive are going to allow too much space for air leakage for an air tight seal. When you apply the gasket material always go over the gasket already applied then cut through both diagonally. That way both back each other so as not to have even the tiniest gap that could compromise the seal.
    I leave a bit of the adhesive paper on the last bit so not to stick to the already applied gasket. Then when you cut through both with a sharp razor you peel up the scrap piece under and finish applying(after paper removal) up to your cut edge and then you'll have a much better seal. Your gasket edges should never end at a screw hole as it also can allow leakage. Always end on solid rim, to make holes just heat up either your soldering iron and poke through or a something you can get hot and hold on to that is round to melt through the gasket just barely smaller than the screw. That way you have good gasket around the screw that will seal well.
    Always make your gasket one piece never more than one to make the journey around the driver, once again it will compromise the seal of the gasket.
    Hope this helps.
    F1nut Posts: 52,038
    Good eyes Ivan, those gaskets are all wrong too.
  • pitdogg2 wrote: »
    Sanjib_a wrote: »
    Hope this helps.
    I will redo the gasket. What is wrong with Dynamat?
    Sanjib_a wrote: »
    Sanjib_a wrote: »
    Hope this helps.
    Dynamat looks good. No need to cover it all a little goes a long way.
    Do you understand what I'm trying to convey here with the gasket?
  • pitdogg2 wrote: »
    Sanjib_a wrote: »
    Sanjib_a wrote: »
    Hope this helps.
    Thank you!
    audioluvr Posts: 5,996
    You need just enough dynomat to dampen the ringing of the baskets. tap on them with your fingernail before and it will "sing" after it will just make a thumping sound. Good enough. I actually went around my cabinet looking for the same thing and found a couple of spots that dynomat helped. Most won't think that's necessary but I'm very happy with the results I got.
  • Schurkey
    Schurkey Posts: 2,122
    Sanjib_a wrote: »
    As is so often the case here, "Loctite Red" is far too ambiguous. Specify a product number so we know WHICH "red" product from Loctite you actually mean. I bet Loctite has a dozen products with red color.
    Taking a wild guess, you mean "271, red high-strength anaerobic thread locker"; and if the magnet was entirely removed from the basket and the pole piece, that's probably a fine adhesive to re-glue them. I used a competing product from 3M; (TL71) essentially the same thing as 271 to reattach the magnet that broke off of a MW6509 that I stupidly dropped on the floor.
    https://www.3m.com/3M/en_US/company-us/all-3m-products/~/3M-Scotch-Weld-Threadlocker-TL71/?N=5002385+3293241418&preselect=8710676+8710815+8745694&rt=rud
    But unless the magnet has entirely detached, that's probably a poor choice. There's another thread where another Loctite thread-locker was suggested, a thin-bodied one that "wicks" into position. (Loctite 290 "Green") I have no experience with that product and speaker magnets.
    https://forum.polkaudio.com/discussion/184463/a-different-twist-on-the-magnet-gluing-process#latest
    We see the same thing when folks talk about "Power Grab", there's multiple formulations, the formulations sold this year may not be the same as the formulations sold five years ago, and some of those formulations are entirely wrong for our magnet-gluing/reinforcing application. But folks here jabber on about "Power Grab" as if there was only one product by that name.
    https://forum.polkaudio.com/discussion/170827/loctite-henkel-power-grab-for-speaker-magnets/p1
  • Schurkey wrote: »
    Sanjib_a wrote: »
    I don't think magnet has moved. I used this one in three places along the joint.
    https://www.homedepot.com/p/Loctite-Power-Grab-Ultimate-9-fl-oz-Construction-Adhesive-1989550/206210490
  • I
    audioluvr wrote: »
    I have previously used Dynamat in the same on my CRS+ and I am very happy with the result.
  • Polk SDA 1C and CRS+, Klipsch Forte II, Focal Chorus 706, Sansui: 9090DB, Eight Deluxe, AU-9900; Pioneer SX-1010, Marantz: 300DC, 3200B, 2325, 2275, Thorens TD-145, Technics SL-1650, Pioneer PL-707, Pioneer RT-707
  • Behind the drivers on the back cabinet inside wall.
    F1nut Posts: 52,038
    That is seriously the wrong stuff. Look for Blackhole 5.
  • [/quote]
    Thanks[/quote]
    Do you understand what I'm trying to convey here with the gasket? [/quote]
    Sorry, I missed your last question. Yes, I understood and corrected it.
    Thanks!
    Sanjib_a wrote: »
    Do not use this.^^^^^
    That is like dynamat and is the wrong stuff.
    Blackhole 5 at
    http://www.soniccraft.com/product_info.php/blackhole-p-50?sort=6a
    Or the sonic barrier is the correct stuff to use. Yes it goes on the back of the cabinet behind the midwoofers only. You still use the poly fil as well. Poly fil goes right back to where it was.
    https://www.parts-express.com/sonic-barrier-1-1-4-3-layer-acoustic-sound-damping-material-with-psa-18-x-24--260-535
  • pitdogg2 wrote: »
    Sanjib_a wrote: »
    Blackhole 5 at
    What is the difference between sonic barriers and sound absorber?
  • Gardenstater
    Gardenstater Posts: 4,804
    Here is another one that you might consider. Some here have expressed the opinion that it is good and I believe the general feeling I have gotten here is that most think Blackhole5 and Norez are superior to the Sonic Barrier. The mfg of the Norez gives a pretty good explanation of why they think their product is superior. They don't actually give the thickness of their damping layer (the one right against the adhesive) but they say it is twice as thick as Blackhole5's damping layer. I just measured my Blackhole5 and the damping layer is about 0.047" fwiw.
    http://gr-research.com/norez24x27sheet.aspx
    I haven't done the mod yet to my 7Bs because I need another piece of Blackhole5, which is what I decided to go with. Very expensive though.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
