Bi-wiring with unterminated speaker wire?
Hi, I have an old power amp I’d like to try out on my lsim 707’s. It only has bare wire connections for the speaker wire. Can I make my own bi-wire using two lengths of unterminated wire, twisting the two red together and two black together on the amplifier end, and connecting the 4 ended side to the dual binding posts of the speaker?
Answers
  • Hermitism
    Hermitism Posts: 4,320
    Yes. You can also terminate the end with pins in case the doubled up wire is too thick to fit in the holes. Terminating the end of the wire and using shrink tubing helps prevent the bare wires from being exposed and tarnishing or turn green over time.
    https://douglasconnection.com/products/diy-and-save-do-it-yourself/diy-cable-kits-2/speaker-cable-connectors/pin-speaker-cable-connectors/
  • Thank you, I think if I stick with 14 gauge wire, the twisted ends will fit in the holes
  • Hermitism
    There is no need to biwire if you are using jumpers on the speakers, unless you are just trying to increase the wire gauge, or if you just wanted to experiment.
    I'm using biwire cables on a system which allowed me to eliminate the stock jumpers. The speakers on that system used a gold plated brass jumper which everyone recommended replacing to help sound quality.
    The guys here will recommend using a good quality wire. Many to choose from in all price ranges.
  • gp4jesus
    gp4jesus Posts: 2,016
    Be CAREFUL with bare ended wire. Examine your connections w/a magnifying glass. Too easy for the tiniest single strand of wire to waste an amp.
    *all connected w/Premiere ICs
  • Gardenstater
    Gardenstater Posts: 4,742
    edited February 2020
    Here's a guide for using WBT Crimping Sleeves with multiple wires:
    http://www.wbtusa.com/pages/CrimpSleeveSelector.html
    http://www.wbtusa.com/pdf/wbt_crimping.pdf
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
