Using REW to measure SDA SRS 1.2
Hi all!
New to this, so please bear with!
Just picked up some near mint SDA SRS 1.2s. Appear to be all original. Did a few measurements with REW using a calibrated mic - getting some weird results. I measured a single speaker, bi-amped, with the interconnect disconnected. Am I doing something wrong?0aqmtipnb0r2.jpg
    F1nut Posts: 52,276
    Yes, everything.
  • verb
    verb Posts: 10,176
    Hey @dubseven welcome! Not familar with REW, but perhaps some folks here are. Hopefully they will be able to help.
    First and foremost, post some pics and tell us about your setup. Speaker positioning for those babies is critical, as well as the listening position. Components are important too, as you'll need some power to drive those babies!
    Not sure why your interconnect cable is disconnected, as that is key for the SDA's to work properly.
    And bi-amping. Lot's of debate on that here. I suggest you start small, don't bi-amp for now. Just hook up one amp for both speakers, and go from there.
    Welcome!
  • delkal
    delkal Posts: 764
    edited November 2019
    Don't be discouraged by F1Nut's reply. He is rude to everyone "new" on this forum (<5-10 years).
    I agree with Verb that you need to find/ make the interconnect cable and not biamping till you get everything set up first.
    Where did you set up the mic when you tested the speaker? While the drivers all look the same the crossover is complicated and many of them play at different ranges, phase , and volume. Same for the tweeters IIRC one is out of phase and the other 3 play with slightly different crossover points and volume. So you can't have the mic closer to one driver than the other. Back the mic off to your listening and play around with height.
    Not sure why you are seeing the big hump at 60 HZ. Do you have a 60 cycle hum in your system?
    F1nut Posts: 52,276
    Nothing rude about my answer, he's doing everything wrong. End of story.
    nooshinjohn Posts: 26,102
    Yes, everything.
    A little wordy for a response from Jesse...
    F1nut Posts: 52,276
    Yep.
  • delkal
    delkal Posts: 764
    Just because he didn't have the interconnect cable hooked up? Is that "everything"?
    You can bi-amp SRS 1.2s so that shouldn't be the problem.
  • dubseven
    Yes, everything.
    Any chance you'd help point me in the right direction?
    verb wrote: »
    Welcome!
    Hey thanks! SDA SRS 1.2, two Ashly FTX2000 amps, DriveRack to split the signal for now until I can get a better setup.
    I have the interconnect cable, but was trying to measure a single speaker - perhaps this was the wrong approach? Do I need to measure them together?
    delkal wrote: »
    I set it about 3-4 feet from the speaker, about half way up. I do have the interconect, should I be measuring both speakers at the same time? I don't recall any 60 cycle hum.
  • dubseven
    Another note - with the interconnect cable hooked up, something just doesn't sound right with the speakers. Which is what prompted me to measure them and see what was up. Feels like there is a big hole in the mid range, and the highs are super weak.
    F1nut Posts: 52,276
    First issue, you're using pro gear, which has no business in home audio. These speakers should be driven with high quality electronics and the amp has to be common ground.
    Testing one speaker as you are doing is pointless, especially with SDA's. The SDA drivers when driven in stereo play at half the volume of the stereo drivers. Without the cable connected the SDA drivers will only play below 150Hz.
    You are not bi-amping unless you use active crossovers.
    Ok, the speakers have issues, which could be a multitude of reasons. Go to VR3's site and download the SDA troubleshooting guide. Lack of treble could indicate bad tweeters. You'll need to pull each one to test. Push in each mid-driver to see that they move. If not the magnet has shifted and locked the voice coil.
  • dubseven
    The manual specifically states how to bi-amp - is this not correct?
    Mid range drivers feel fine, will check tweeters! Thanks!
    F1nut Posts: 52,276
    Yes, it shows two ways to bi-amp, the only one that is true bi-amping is the one with the active crossover.
    Forget about that right now, get a high quality home audio stereo amplifier and pre amp after you figure out what's wrong with the speakers.
    VR3 Posts: 29,687
    May also have a bad poly switch
    F1nut Posts: 52,276
    VR3 wrote: »
    In that case all he'd hear is mud.
    VR3 Posts: 29,687
    Kind of sounds like that is what he is hearing
    "Feels like there is a big hole in the mid range, and the highs are super weak"
    Sounds muddy to me
  • ptrooper
    ptrooper Posts: 535
    Don't fire truck around with them,bomb them out and listen to them until your deaf because they will out live you!. >:)
  • K_M
    K_M Posts: 1,631
    verb wrote: »
    Welcome!
    I would assume to measure frequency response of one speaker specifically, he is running just one without the cable, to avoid any measuring issues or artifacts.
  • dubseven
    K_M wrote: »
    Yeah, that was the idea, albeit likely incorrect
    The problem with that is you have to a stereo pair to get both speakers to function correctly. Trying to measure just one speaker renders 4 of the mid-woofers inoperable, causing the passive to not function correctly and the non working drivers to also function passively.
    Your measurements will be all over the place.
  • dubseven
    Two things. The third tweeter from the top on both speakers appear to be dead - coincidence, or would something else cause both to be inop?
    Second, new sweep with both speakers and interconnect hooked up, mic placed inbetween speakers about 8ft back.li9oqpda5dto.jpg
    pitdogg2 Posts: 27,745
    tweeters are progressive point source top full hot then get quieter going to the bottom.
    mhardy6647 Posts: 35,501
    1) where's the mic relative to the loudspeakers?
    2) what's the room like as an environment (e.g., size, shape, floor covering, windows? drapes? wall hangings? 'sound treatment'?)
    A diagram may be the best way to address 1)
  • dubseven
    Switched to single amp, re-measured. The 3rd tweeter definitely848y7f2lhjnz.jpg
    dead in both.
  • ptrooper
    ptrooper Posts: 535
    swap the tweeters around to see if its the resistor!
  • dubseven
    ptrooper wrote: »
    Just pulled one out and checked resistance, its an open loop.
  • ptrooper
    ptrooper Posts: 535
    Replace the tweeters to rdo 198's if the speakers are definitely 1.2 TL's(check rear serial number area) ,these will replace the sl3000 which are a silver looking dome version.The sl2000 "white with black cloth looking ctr"are replaced by the rdo 194's.If your speakers are not 1.2 "tl's" , i would think seriously think about moding them to take the 198's.
    Replacing the tweeters is a nice positive upgrade
    "mint condition", gratz and nice score.
  • dubseven
    I dont believe they are TLs. The tweeters are SL2000s.
  • ptrooper
    ptrooper Posts: 535
    Are they definately 1.2's or SDA SRS? check serial number,if thats missing,you'll have to check the drivers individually as the SDA SRS are a different animal to the 1.2's and tl's .
  • dubseven
    They are SDA SRS 1.2.
    8 mids, 4 tweeters each.
  • ptrooper
    ptrooper Posts: 535
    I would just replace the blown tweets for now and listen while you look seriously into upgrading them in the future.There is plenty information on here to do some cheep upgrades like dynamiting the basket drivers and adding black hole 5 or another dampening product to rear inside cabinet behind the drivers.
    Glueing the magnets so they never move in the future is a "must do".
    The speakers must be sealed properly, pushing in gently on the radiator and holding in , the 8 drivers should slowly move back in and should only take about 3 seconds or more.
    If this is not for you they will definately sell easy enough.
    As they say in here "Welcome to the rabbit hole"
    They are keepers
