FS: SVS PB12 Ultra/2
Selling this old school SVS sub, going to build an IB setup so will have nowhere to put this one. Bought new from SVS some years ago. It's the black finish with no dents, dings or scratches. It does have an issue with the input,if you wiggle the rca cable it will feedback through the sub, not an issue unless the cable is moved. I plan to take a look at that this weekend. This thing is huge so local pickup only. I'm located about 20 mins outside of Nashville. You’re welcome to listen before purchase. Asking $700.
I’m new to this forum but have this listed on AVS as well. I have trader feedback on other forums I can share if needed.n7pwdn7abtzv.jpeg
Here are the specs:
SVS PB12-Ultra/2 Specifications
· Twin TV-12 "Ultra" woofers built by TC-Sounds... SVS's best
· 1,000 watt BASH (R) amp with built-in parametric equalizer
· Flush-mount amp configuration (220v. version available)
· Computer Assisted Design (CAD) enclosure
· Down-firing configuration with distinctive SVS integrated base-plate
· Compliant floor mounts , low center of gravity
· Three 4" high-flow flared porting (in and out), two port blocks included.
· Each sub built and tested by SVS in its Ohio factory.
· Extra heavy-duty detachable 8 foot power cord
· Hand finished in four hardwood veneers, gloss or fine textured black
· Selectable 16Hz, 20Hz or 25Hz extension with included port plugs
· +/- 2 dB 18 Hz-200 Hz anechoic in 20hz mode **
· Size: Approx. 19" wide, 26.5" tall and 28" deep. Weight: 190 pounds
Sent from my SM-G950U using Tapatalk
    Clipdat Posts: 13,095
    lloyd401 wrote: »
    You need to have 100 posts before making a post in the FS section.
    I guess you missed the "before you post, read this" sticky at the top of the FS section. I'll link it here for you: https://forum.polkaudio.com/discussion/98162/before-you-post-read-this
  • Bgoodfella
    Bgoodfella Posts: 107
    Nice sub. One day I'd like to have one.
    (2) Rti A7's
    (1) CSI A6
    (2) FXi A6's
    Denon AVR - X4300H
    Monster 850i interconnects ( not sure what everyone hates about these - maybe my untrained ears are too innocent to know what's bad)
    Parasound HCA2205A amplifier
    Sony XBR65X900E TV
  • maingey
    maingey Posts: 632
    edited May 2019
  • lloyd401
    lloyd401 Posts: 2
    $650, can drive a couple hours to meet if needed.
  • dromunds
    dromunds Posts: 10,123
    Dude, please comply with the rules for selling. You need 100 posts, as you were told more than a month ago.
  • verb
    verb Posts: 10,176
    Really brother hang out for a while! Tell us about your system, ask questions, get to know us, if your're really interested. Honestly no one here is really gonna buy from you if we don't know you.
    Hey if that's not your thing, all good. Craigslist is your friend.
    And welcome BTW! :smile:
