Sub or not
rburgess714
I have been running hybrid ht/2-channel rig in 3.0 no sub. My Sig 60s have plenty of low end and I am not a bass head. Other than more boom on movies in ht what am I missing when listening to music in 2-channel? I have considered a SVS SB2000 but want to know if it’s worth it?
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
Office
A nice, musical sub can take over the low-low duties, and may result in cleaner delivery with what you leave for your speakers to handle.
If you have a wide open space that's difficult to fully pressurize, a sub can help tremendously with that, and provide the sense of a fuller sound across the lower frequencies.I disabled signatures. -
Hey Scott - The room is pretty open but sub placement would be limited to a corner and I am concerned that the low end would become isolated.
So a musical sub would offer cleaner mid bass?Living Room
Office
Douglas Connection ICs and Cables -
rburgess714 wrote: »A nice, musical sub can take over the low-low duties, and may result in cleaner delivery with what you leave for your speakers to handle.
I meant cleaner mids from the 60s?
Btw- how’s the new integrated?
Living Room
Office
hehe, so this is about as far as I get - subs make bass
I don't have enough experience yet with what's what in the ranges. I suppose I should pay more attention to that...
The neat thing about subs is that when they're properly placed, they can be difficult to source-locate. IF you're not really listening too hard for it.
But yes, sometimes when speakers are really busy, you can get congestion, and the music details sort of get lost in it. You've most likely experienced this. I can come across as kind of distortion. You can lose the layering, and everything can sound very flat.
If you can pull the heavier lows out to a sub, the result can be that the mains drivers are better controlled. This can result in an improvement in clarity and separation of the musical components, because everything won't be running together trying to play at once out of the speakers, none of it working particularly well.
I suppose a good starting question would be, do you feel things muddied up any on particularly busy, fast music? Or in anything with some low end sustain?
If your speakers are too busy, and you get that addressed, it can open the way for some refinements in the music, like hearing details you haven't heard before, imaging - that sense of instrument and player location - and other stuff I don't know a whole lot about. I've only rarely experienced imaging refinements past a strong center image in full size systems because my rooms are all weird, but I've been playing around with near field stuff a little, which is easier to get those results with. Purely by accident, I might add. It's really something when you experience it. I can't even describe how cool an experience it is. It's just something "neat" that never seems to get old.
The new integrated was great in the test space, but I'm fighting a few things in the main space, which is wide open and seems to have a bass suckout. Been crazy at work lately, so I haven't had much time to work on that. I may either need to run a sub with the A5 - here's a similar example - or move it to a different space without the room issues.I disabled signatures. -
Yeah I think I need to experiment just something else to to play around with. Thinking Rel or SVS.
Good luck getting the A5 dialed in, that a beast of an integrated.Living Room
Office
Sub or not depends on what your space does to your speakers frequency response. You may own a speaker that measures 25Hz to 25KHz +- 3dB, but your room may actually measure -10-15dB in the 25-35Hz range.
If you don't listen to anything that goes that low, you are not missing anything. Check a musical instrument frequency chart and see how low instruments play in music you like to listen to. A room sweep will tell you what you may be missing or frequencies that are boosted.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
If you're going to do room sweeps I've found this to work quite well.
Do not use synthetic or colored ones. They can taint the readings.
As an option for an easier and digital solution:
Aaron
Enabler Extraordinaire -
What MSG says basically......
Smallish woofers never can do mids and truly deep bass well, at loud volumes and with low distortion.
The sub takes the load off of smallish woofers and more efficiently produces lows.
It is not just a matter or your mains speakers having or not having bass, but relieving the load on the amp and speakers at same time.
Cleaner bass and mids. -
Smallish woofers never can do mids and bass well, at loud volumes and with low distortion.
Clearly you've never heard PMC speakers. -
All due respect to previous responses - to produce accurate bass, you have to move air, and the lower the frequency, the more air you have to move. Cone size and/or cone excursion are the ways to do this. I realize that enclosure size, enclosure type and amp power all play a role as well, but in all but the most complex designs, the size of the driver and it’s excursion potential will determine the depth of the bass you can expect to get. The driver compliment in most main speakers (especially bookshelves) simply are not capable of truly deep bass at significant output levels.
Subs with servo circuits are in my opinion the preferred way to go, especially for music (2ch). I have difficulty envisioning a music type that would not benefit from a quality sub, correctly integrated into the system - maybe a’capela vocals...
Anyway, once you’ve heard 2ch music through a system utilizing a well integrated sub, you’ll most likely be hooked:-)
Happy shopping!“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
The SVS SB-2000 is EXCELLENT and (by far), the best Sub I've auditioned. Many were boomy/thumpy and more of a gimmick than useful.
The SB-2000 is a beautiful unit in piano-black.
Mine is NOT in a corner but is just outside of my main stereo speaker array which is open (to the right side).
It can't be pinpointed as far as location goes.
The variable Phase and Volume controls make it very easy to fine tune.
Is a Sub "needed" in my case? No, as the speakers I am using dive deep.
Do I like it? Absolutely, and it is particularly valuable during lower volume listening sessions and for a bit more "kick" when watching movies.
I think it is worth every cent. -
Just simple physics.
Small, loud and deep and low distortion never can happen.
You can choose one factor, but not all.
You need large cone size and large excursion to do all. -
Since I'm sorta considering this myself, what would be some example brands/models of servo circuit subs? When someone says their sub has a motor, is this a servo type sub they're talking about?
We had an older velodyne that used a control circuit, worked great for many years, was impressive.
Have no owned their newer ones though. -
Thank you for confirming that you've never heard PMC speakers. -
Thanks, I can borrow the neighbors when she isn't using it.
Check out Rythmik.
http://rythmikaudio.com/technology.html
With all due respect, your space determines your speakers frequency response. Why add a sub if you don't need it? Do the work, do a room sweep to determine the rooms frequency response. Positioning can help fix issues along with acoustic treatments.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Velodyne and Rythmik are the front-runners in servo subs ATM....
“Motor” can refer to the “motor assembly”, which is the voice coil, magnet, and spider. It “can” also mean servo, but not necessarily. Typically, if a model includes a servo circuit, they’ll usually make sure you know:-)“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
Provide a link to the model you are referring to please.
Are you saying these PMC speakers somehow defy physics? -
I presumed you hadn't ever heard PMC speakers, and then your non-answer confirmed it. That's it, we're done here.
I think you should avoid making blanket "absolute" statements such as "Smallish woofers never can do mids and bass well, at loud volumes and with low distortion." or you will come across as someone who is talking about things that they don't know about. -
I will also mention that you said a small driver cannot do mids well, the OP has S60s with a 6.5 inch driver (multiple obviously) so I don't want him to get the impression a 6.5 inch driver can't do mids or bass well....if it couldn't why would we all love these MW65XX model drivers?Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
rburgess714 wrote: »I have been running hybrid ht/2-channel rig in 3.0 no sub. My Sig 60s have plenty of low end and I am not a bass head. Other than more boom on movies in ht what am I missing when listening to music in 2-channel? I have considered a SVS SB2000 but want to know if it’s worth it?
Try it and see! 45 day return policy, pretty sweet.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Hoffman's Iron law of speaker building.
Read it well, then come back and see if you understand.
If you do not, I can explain it better to you.....as other's further up have tried.
If you are just singling out my post, then move on. -
codycatalist wrote: »I will also mention that you said a small driver cannot do mids well, the OP has S60s with a 6.5 inch driver (multiple obviously) so I don't want him to get the impression a 6.5 inch driver can't do mids or bass well....if it couldn't why would we all love these MW65XX model drivers?
I said small woofers can not do mids well, AND deep bass, AND loud levels, AND with low distortion.
Not quite the same. -
SCompRacer wrote: »Check out Rythmik.
Hey Rich, how might I go about doing a room sweep?
Kelly, please retain that message in your thoughts
I’m sure you can use it yourself again some day2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »
Please Contribute to the thread, as I did.
The pile on mentality, you guys seem unable to resist doing, is bringing the forum down. Is that truly your only intention?
The only issue, is that moving seating position can greatly influence the bass you hear, due to standing waves cancellations and reinforcements.
So what may measure good at one point, will be totally different in other areas.
Room treatments can minmize the swings, but not eliminate them totally.
In a normal sized room, it is always a compromise.
If you do a room sweep from a digital source or test cd, you will hear the peaks and valleys associated with the reinforcements and cancellations AT that particular location in room.
Also you will see how much deep bass is present or not present in the room/speaker interface.
We used a tone generator on one comp, hooked up to some of our systems, and you can scroll through frequencies or have it sweep very slowly and observe the bass. -
For free software, look at REW. IIRC you had to belong to a forum to download. REW uses burst tones. Playing single frequency tones for long periods can give you inaccurate readings due to room loading.
You'll need a microphone with a calibration file. If you have a Radio Shack meter, you can also use those. Check out this page, getting started with REW. It covers mic's.
https://www.roomeqwizard.com/help/help_en-GB/html/gettingstarted.html
I purchased Dayton Audio Omni Mic V2. Like $300. It is supplied with a calibrated mic. You can also use the Dayton software for testing DIY speakers.
http://www.daytonaudio.com/index.php/omnimic-v2-precision-measurement-system.html
Place the mic in seating position. Do the sweep and see the results. Remember, we are placing speakers in rooms not designed for audio.
I have moved speakers and applied acoustic treatments to improve readings in the mid range. Keep notes of what you did and what happened. Sometimes you just have to put the software away and go back to it another day. Be prepared to compromise.
Then I worked on sub placement. In my room, in the listening position, you get everything. Other positions in room, not as good. If I move forward I get nulling of the bass until it disappears, move a bit more and then it reappears. All I care about is the sweet spot.
Best placement of subs for me was between speakers and tight against the wall. For my space which is over 10,000 cubic feet (an open main level), recommendations were for two 15" subs. I went with two 12's as they are smaller and were just enough to give me the boost I needed in the 25-35Hz range.
Most likely you won't get your room response ruler flat but you can get it closer and more enjoyable.
Victor (halo) has REW and was going to do some sweeps. Hopefully he will post results and folks can help one another out with the software.
That's a cool tip that I did not know. Thanks! My HSU came with a test disc, but the different tones are constant.SCompRacer wrote: » -
I made 2 attempts in the last 12yrs to integrate an SVS sub in my 2 channel, neither one worked long term. Just didn't care for it.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
