Polk LSiM703 - harsh treble vs LSi9 or in general? How to fix?
13»
    heiney9 Posts: 25,490
    edited March 2019
  • sponger
    sponger Posts: 325
    It's a relief to hear that the OP's dilemma was solved. But, if it was a source issue as it appears to have been in this case, then why was he satisfied with his LSi9? Perhaps the answer is that the LSi9 is a less resolving speaker than the LSiM, masking the limitations of the Fosgate amp. But, is the LSiM so much more resolving that it made that much of a difference to the OP's ears? Is it a coincidence that the Parasound amp is delivering significantly more power at 8 ohms? Could that not a be a major factor in the improvement?
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • erniejade
    erniejade Posts: 6,321
    Yes to all
  • CottageChz
    CottageChz Posts: 417
    sponger wrote: »
    I agree that it could be either of these things, power or more resolving speaker. I personally found the LSi9s to have less treble/be less bright in general, so that probably plays into it as well, whether that's just the nature of the speaker, or the speaker being more resolving, or some of both. But I was also never able to try the LSi9s with the Parasound, obviously. Would love to give the speakers a try side by side with my new amp... if only I still had the 9s. Ha.
  • K_M
    K_M Posts: 1,631
    edited March 2019
    sponger wrote: »
    The lsi and lsim Series both use a very similar tweeter. (Vifa ring radiator)
    If anything the LsiM is simply voiced about 3-4 db or so hotter in the treble.
    Response graphs were posted earlier in the thread......
    nooshinjohn Posts: 25,973
    The tweets are only related by the fact they call them tweeters. Their similar appearance does not mean they are anything more than distant cousins.
