Proper orientation of male split pin RCA plug
mlistens03 wrote: »
Apparently I’ve been ignored. I’m not quite sure what I did. Can someone enlighten me?mlistens03 wrote: »
Congrats, you just joined the class clown and clipdik on my list. Shame, I thought you might turn out ok.....oh well.
I would tell you but I am pretending to ignore you. -
Wondering if someone can help shed some light on the proper orientation of a male RCA plug with a split pin, in regards to how to correctly insert it into a female RCA jack.
I notice that with the split pin cables, that when I'm plugging them in and they rotate slightly, sometimes I can hear and feel what I'm guessing is the metal inside getting stuck on the split of the pin slightly. It makes a little twang sound, like it stuck for a second and then releases.
Looking inside a female RCA jack, there appears to be a horizontal piece of metal. I'm guessing this is what makes contact with the male pin and transfers the signal.
Now, in regards to the split pin, how should this be plugged in to make "proper" contact? If I plug it in so that the split is sitting exactly horizontal, then the horizontal metal inside the jack will actually get inserted inbetween the split tip! I can't imagine that is ideal..??
If anyone has a diagram of what the inside of a female RCA jack looks like, maybe that would help. Or any insights from people who having experience using RCA interconnects with split pins. Thanks.
The below image may help explain the issue you're having. The center contact is simply a "spear" that is designed to engage the pin of the male connector, then deflect slightly during insertion while still maintaining contact.
Should be not an issue with a solid pin connector. Nice smooth rounded end.
However with a split pin, you have a cut right down the middle of the pin, introducing essentially a "slot" with two sharp edges. Not smooth by any means. Not hard to imagine an orientation of the slot engaging the end of the spear! At that point, the spear may actually be partially engaged in the slot, and with a little twist you bend the spear out of the way, once out of the way, twang!, the spear comes back to it's normal position.
Just a theory of course, would have to be verified via experimentation. FWIW.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Nice explanation, that's exactly what's occurring! Now I know why you get paid the big bucks!
You can see the "U-shaped" piece of metal that I was trying to describe on the left hand female RCA jack above. Both the sides and the end of it are what can get caught in the split tip.
So, it seems like the split tip cables would work best for higher quality RCA jacks that feature a full 360 degree cup for the tip to sit in, versus the cheaper/more common style that are on most gear.
At this point the split tip seems like a bit of a marketing gimmick, imo. -
Is there a supposed reason for the split tip? I've only ever seen it and I thought it was some way to make the cables cheaper.
I'm not an expert, but I believe they're designed to mate with a better quality RCA jack (cylindrical IIRC) instead of the spear type. The spear type is about as inexpensive as it gets.
The split types are designed to deflect themselves (spring loaded) upon insertion, to ensure good contact along the entire mating surfaces, and keep good retention.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Here's some marketing gibberish I've found just now regarding split pins:
Split Pin Technology Ensures a Secure Connection.
split-tipped center pin to ensure a tight connection and flawless signal transfer.
the split pin and collar gold-plated RCA's also maintain a robust signal path and longevity.
Split center pin allows for superior signal transfer
split tip center pin and segmented shield for maximum contact and reliability
The split types are designed to deflect themselves (spring loaded) upon insertion, to ensure good contact along the entire mating surfaces, and keep good retention.Here's some marketing gibberish I've found just now regarding split pins:
nice idea, but it doesn't seem like a winner to me... basically, your paying more money for less material?Marketing lies at its best....
definitely. -
Marketing BS at its best....
Indeed....same people who wrote that probably also write for womens magazines.
lsi 9's -
However the issue/situation here is that for a cable that has some weight/body to it, when you plug one end in, and then attempt to run it to the other piece of gear you are connecting, the weight and bulk of the cable can actually inadvertently rotate the plug in the jack.
How about....resting the plug inside the jack without inserting all the way, then when the other end is connected, and the weight of the cable settles....you push it in. That way no additional turning happens.HT SYSTEM-
lsi 9's -
Know it all!!! -
I have Anthem equipment. They advise against these types of connectors. In fact they say in the owners manual that they will not repair under warranty any jacks damaged by this type connector. The argument is these will snag causing damage too the jack internals.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey.
Religion began when the first scoundrel met the first fool……….Voltaire. -
I think I need to go lay down........Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
