Monitor 10B Drivers
Good morning y'all. I have a couple sets of 10Bs and one of my drivers blew. It has happened before but I have used my 2 spares. It has been a while, but I seem to remember that there were two different drivers and I wanted to be sure that I picked up the right ones. I know I could have probably found this info if I was better at searching but I appreciate any help y'all can give me.
Best Answers
pitdogg2 Posts: 17,968
have you looked at the drivers in the speaker? That is where I would start and then replace with the same driver number. Yours should be MW6503 -
westmassguy Posts: 6,743
The earliest were unmarked unpainted and were MW6500s, I've also see MW6600X, and MW6503Home Theater/2 Channel:
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards -
westmassguy wrote: »The earliest were unmarked unpainted and were MW6500s, I've also see MW6600X, and MW6503
That's interesting Dave I knew they did come with MW6500 in the beginning. Looking at the schematic's provided by Polk the only drivers mentioned are MW6501 Which I believe could of been a MW6600 as those MW6600's were popular with early Polks. All later have MW6503 listed. One would think anything 10B would of been MW6503, but we also know how Polk switched up on the fly many times.
Answers
Forgot the 6501s, seen them too. A lot of happy campers were working in the assembly area from what I've gathered.
Den:
Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
"Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
"50% Why... That's almost half."
"I know, I'm sick and need help."
Gimpod Custom 4th & 5th Gen SDA Circuit Boards
"The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
What are you trien to say? What is this wacky weed that you speak of?
