Polk Audio SDA SRS - Clarity : Duelund : Jantzen : DH Labs
VR3
VR3 Posts: 29,565
edited February 2017 in DIY, Mods & Tweaks
This is my 2nd SRS build using these components, I modified the chassis particularly for this build. This is the first time I also built a DH Labs Q-10 SDA cable :)
Clarity Cap MR through out except in the larger values where ESA was used
Duelund resistors
Jantzen inductors + C-Coil
Supra Internal Wiring, WBT binding post
DH Labs SDA cable
(Polk logo was used at the request of the owner and is not offered under normal circumstances, will be blurred out on my website when posted)
    VR3 Posts: 29,565
    Compared to standard SDA SRS
  • zingo
    zingo Posts: 11,258
    Fantastic! I love Jantzen components and DH Labs wiring; nice choice.
    VR3 Posts: 29,565
    Thank you! I am a huge DH Labs fan, but the Q-10 at like $25 or something a foot is up there, I used it for my super towers though and I would put the sound quality with MIT....
    I don't go into pricing on the forum but feel free to shoot me a PM or check out my website :)
    VR3 Posts: 29,565
    The first build is "The Abbott" and the second one is "Monastery Standard"
    VR3 Posts: 29,565
    Most definitely! The Abbott builds are my favorites to do. I actually have another SDA SRS Abbott that will be coming out in the next few months, same price point but will use the new CMR and CSA capacitors and the Duelund Cast resistor set... should be a slight notch over the current Abbott... should have pictures in May or so
    I also do deposits/payment plans :)
    VR3 Posts: 29,565
    So in regards to the standard and the Abbott...
    I always describe all modifications as "removing a blanket" from the speakers. The standard fall into that description, everything kind of opens up, detail is brought out, bass is extended, sound stage is wider, etc etc etc...
    The best way I can describe the Abbott from the Standard build is that the speakers start to disappear and what you are left with is a 3-D presentation of what is in the recording. You start to hear the shape, resonance, texture of a guitar, who is holding it, where they are in the room, depth to their scale compared to other instruments/musicians in the mix.
    From a "detail and transparency" standard, I would say a standard build is 85-90% of that. From the stand point of transporting you to the mix versus listening to a set of speakers, the Clarity Cap MR has no competition. It is one of the best experiences I have ever heard, especially after break in.
    Phil @Moose68Bash actually wrote up a review going from one of my standard builds to an Abbott build. He really captured the difference with his words.
    http://forum.polkaudio.com/discussion/167764/review-vr3-mods-s-monastery-level-the-abbot-srs1-2-to-srs12tl-conversion#latest
    The SRS differs from the 1.2 and 1.2TL all the way down to the enclosure, I wouldn't particularly recommend trying to shoe horn a 1.2TL into a SDA SRS shell personally due to the driver, enclosure, etc differences.
    I do have a set of 1.2TL here that I am offering 20% off an Abbott build, plus the modifications themselves are less than the SRS Abbott build....
    So as an example, you can take the 1.2TL, modifications installed for only around a $1,000 more than the SRS modification... just an example.
    On the flip side, I cant determine if with hearing loss one is worth more than the other...
    I hope that helps... :)
    VR3 Posts: 29,565
    I just wrote up a really nice response.... and it didn't load up here for some reason...
    I don't really like "over-selling" things - Phil @Moose68Bash actually did a standard build like the Monastery standard to the Abbott on a pair of 1.2TL... his write up is here -
    For me personally, I feel detail and transparency wise, the standard build is 85-90% of the Abbott... on the flip side I feel from the stand point of making the speakers disappear, texture, 3-d reproduction, the Abbott components take it to a whole new level. It is one of the only experiences where I would call it "being there" - you can sense the size, shape of a guitar, who is holding it and where, the texture of everything. It is hard to describe. I did a similar modification to my own personal speakers back in 2011 and that is why I am still doing it here today.
    I cant decide though if the differences are worth it for you unfortunately, I take a lot of pride in my work and I think you would enjoy it. I do appreciate your service and sacrifice.
    On the flip side, I do have a set of 1.2TL, that when purchased with modifications, the modifications are 20% off. You could literally have a set of Abbott modified 1.2TL (installed) for a little over a $1,000 more than the SRS Abbot build by itself... :)
    I hope this helps (hopefully this response posts)
    VR3 Posts: 29,565
    On that response I missed one of your questions, I apologize.
    The SDA SRS is different down to the enclosure, I wouldn't personally recommend updating the SRS to the 1.2TL
  • ptrooper
    ptrooper Posts: 501
    VR3 wrote: »
    Duelund resistors
    DH Labs SDA cable
    Thanks Trey. These Arrived today here downunder ,they were professionally packed to absorb any sort of high velocity impact which we all know is truly needed in this day and age
    VR3 Posts: 29,565
    Glad they arrived safe! 70 pounds in crossovers is no joke hehe
    F1nut Posts: 52,044
    ptrooper is going to be very happy man. B)
  • ptrooper
    ptrooper Posts: 501
    Rings are back from the powde coaters so all systems are go
    Toolfan66 Posts: 18,223
    VR3 Posts: 29,565
    Those turned out great!
  • machone
    machone Posts: 1,568
    I like it!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • honestaquarian
    honestaquarian Posts: 3,259
    I like'em too.
    Not trying to be a buzz kill,but since they're going inside the cabinets and can't be seen from the outside. Why powder coat them?
    F1nut Posts: 52,044
    So they do not develop surface rust.
    F1nut Posts: 52,044
    It's really not a big deal. The surface rust on a set of rings I installed years ago is next to nothing. Now, if you lived in a hot, humid climate without air conditioning or at the beach I'm sure it could become an issue after many years.
  • ptrooper
    ptrooper Posts: 501
    edited March 2017
    Its mind over matter.......if you don't Mind ,it don't Matter .....today i hooked it all up and now its burning away ..... :pkibyj93pg34q.jpg
    Post edited by ptrooper on
  • machone
    Nice!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Magnifico!
    VR3 Posts: 29,565
    Thanks guys! Those plates look great on the speakers!
    VR3 Posts: 29,565
    VR3 Posts: 29,565
    Clarity Cap CMR and CSA - will look slick on the white chassis!
    VR3 Posts: 29,565
    VR3 Posts: 29,565
    lol, thank you :)
    I had a customer a few years had me do a build with a window and a blue led light, that was a lot of fun... :p
    VR3 Posts: 29,565
    VR3 Posts: 29,565
    Coming right along
