PSW505 crackling, low static sound "CS was great!"
LeeM
Well,
Powered on the home theater system this morning to watch a movie and was surprised I started getting this static, crackling sound out of my PSW505 sub woofer which I had for 2 years. When I turned it off to check connections and such it made this loud squeal when turning off wow woke me up. So I disconnected, reconnect it and was getting low level crackling with the bass which was almost none existent. Watching the power light on back every time it played bass the light turned red then back to green. Unplugged again now nothing red light only.
Called Polk CS and talked to Ken, told him what happened took my information and now sending me new amp
All I can say is wow factor on the CS. Will update when new amp is here.
Thank you,
Thank you,
Did you have to send your old amp to them? I am having the same issue, but was told I needed to remove the faulty amp and send it to California. Which I haven't had the time to do as of yet.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
They didn't asked for it back, but if they send a return post with the new one. No problem. I was only on the phone for 5 minutes or less
Thanks.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
When sending out an amp for replacement, do they email you a tracking number?
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I believe they do, providing an email address has been provided.
