New Receiver prospects
13»
  • Thorton
    Thorton Posts: 1,324
    Welcome to the Marantz family. Enjoy!
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Thorton
    rpf65 wrote: »
    Congrats on the AVR, and convincing the wife to allow you to buy it.
    Most bass issues are caused by the room itself or bad positioning. If you have the sub jammed in a corner, for instance, you add a lot of room gain. Sometimes moving a sub by 6 inches or so solves a lot of issues.
    I'd do a sub crawl, and start over if I were you.
    Agree. Also look at threads on the AVS forum for setting up Audyssey and the Sub Distance Tweak. Setting up the sub for great integration takes some time.
    DAC: Bricasti M1SE
  • Nightfall
    Nightfall Posts: 10,083
    papatom wrote: »
    I've always bought the lower end receivers thinking they were "awesome" but boy or boy, little did I know what I was missing once I started using the Marantz.
    That same jump in quality you just had can be had again with a real 2 channel preamp and dedicated amplifier.
    Enjoy.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • papatom
    papatom Posts: 137
    Thank you so much everyone! Very excited! I'll definitely start bass adjustments and positions this weekend.
    Marantz SR5011 / Polk Audio Signature S55 towers / Polk Audio Signature S35 Center/ Polk Audio Signature S15 surrounds / Velodyne DPS-10 / Samsung 60" KS8000 / Samsung UBD-K8500
  • Upstatemax
    Upstatemax Posts: 2,836
    glad you're loving it!
    If you want advice on how to control your audio habit, you should talk to Joey...
    :D
  • papatom
    papatom Posts: 137
    Hey guys, need your opinion here. On my old receivers, never had to choose "large/small" or "full range" speakers before. I have two questions:
    1. The S55s as my fronts, the Marantz is setting yhem to large speakers, with crossover as full range. I have a Velodyne DPS-10 sub. I would set the S55s as small, correct?
    2. What would I set the crossover to for the fronts, 80hz?
    Just looking to tweak the bass a little. Thanks a bunch guys!
  • Nightfall
    Try both and stick with what sounds best to you. Small and 80hz would afford you some dynamics but you might like how large sounds better.
    afterburnt wrote: »
  • rpf65
    rpf65 Posts: 2,127
    Think a 40 Hz cutoff may be a little low. Freq specs aren't listed, but two 6.5 inch drivers, I would think lower limits would be somewhere around 35 Hz or so. Probably wouldn't try anything below about 50 Hz myself.
  • papatom
    papatom Posts: 137
    Thanks guys! All good suggestions to try. I'll experiment!
    txcoastal1 Posts: 13,519
    Blending for 2-channel with sub
    Really depends on room size/location and speaker capabilities and roll off
    Even subs have variable performances in mid/low frequency. When integrating a sub never assume anything...IMHO there is no rule
