Please help! Looking for SDA/Monitor black vinyl or equivalent. Donor cabinet?
gwg_97
I picked up a pair of 3.1tls for a very good price yesterday but the cabinets are pretty beat up. Apparently, one of the previous owners had a minor candle related incident that melted part of the grill cover and about a 4"x4" piece of the textured vinyl located around the drivers.
Does anyone out there know where to find a good replacement vinyl? Another and likely better alternative might be to find an old unused SDA cabinet (that is equal to or larger than the 3.1tl) and use the vinyl on the back of it as donor material. I assume I could carefully remove the donor vinyl from the monkey coffin (using heat) and then glue it on my speaker. What do you think? Thanks!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Check out this thread.
http://forum.polkaudio.com/discussion/172176/sda-crs-with-an-external-crossover-twist/p5Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thanks for the suggestion Vmaxer. That wrap looks like a very good option. Those crs(s) are sick! Here is my project.
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded -
OUCH!!!Does anyone out there know where to find a good replacement vinyl?
I've never been able to find the same material that Polk used on the front bezel and rear panel. Neither has anyone else to my knowledge.I assume I could carefully remove the donor vinyl from the monkey coffin (using heat) and then glue it on my speaker.
Never happen, it'll be ruined if you try to remove it.
The end caps are oak veneer, you'll have no problem finding that.Political Correctness'.........defined
President of Club Polk -
I thought I had seen every way that SDAs can be abused.Proud and loyal citizen of the Digital Domain and Solid State Country!
Check with Parts Express, They have textured black psa vinyl might work for you.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Unfortunately, they don't carry it anymore Randy. That was my first thought as well.RandyCroissant wrote: »Check with Parts Express, They have textured black psa vinyl might work for you.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Minor candle damage ? Holy sh%t. Prior owner clearly failed my assertion that cats, kids, candles, rattling chotkes, and live watered plants do not live well together w/ speakers, ever.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Yes indeed, and I will also add large aquariums and toddlers that like to poke things to that list.
Dang, that's bad, sheesh. Sorry, no recommendations from me unfortunately though. When my kids were "toddlers" they poked at the speakers..., one time...Remember, when you're running from something, you're running to something...-me
