DAC $300 Budget
I'm considering the following, please let me know your thoughts and experience
Dacmagic 100
DACitX
Musical fidelity v90
I'm leaning toward the Cambridge, unless...
    EndersShadow Posts: 17,705
    1. DACitX
    2. Dacmagic 100
    3. MF V90
    That's the order Id go.....
  • Nightfall
    Nightfall Posts: 10,084
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,121
    I love my arcam rDAC. The new version is supposed to be a LOT better and is getting really good reviews, but it's also out of ur price range...
    Game Room 5.1.4:
    Bedroom 2.1
  • That Marantz HD-DAC1 would look gorgeous with the old AV560 I purchased yesterday
  • I really like the sound of the Wolfson in the onkyo Integrated, but it is far from their premier chip. That's why I was leaning toward the Cambridge, but I hear lots of good things on the Sabre. Hmmm...this isn't getting easier.
  • DSkip wrote: »
    Find a used Essence HDACC. Great sound and an hdmi input for better flexibility.
    ^^^This is number two on the DAC list of wants.
    I'm getting DACed to pieces!
  • Thoughts on the Micromega MyDac, it has some great reviews.
    http://www.musicdirect.com/p-106045-micromega-mydac-asynchronous-usb-dac.aspx
  • DaveHo
    DaveHo Posts: 3,583
    Marantz AV560? I owned one of those long ago, briefly. Bought it unheard off Audiogon because it was a step-up feature wise from what I was using at the time. Have you spent any time listening to it yet? I hate to put a damper on your purchase, but that pre-amp was, by far, one of the worst sounding pieces I've ever owned. Lifeless, flat, horrible sound stage, boring. Hopefully, whatever you're mating it with will be better.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited January 2016
    I have actually owned one about six years ago and had it paired with a Yamaha M-60 and Monitor 10's. It was glorious is my basement rig. The background on that piece was extremely quiet and the tuner did a great job as well. I also liked that no matter how high I turned the volume there was never any hiss from my tweeters. Basically it is only going to serve as a volume control and tuner in my den system, as I realized all other features are terribly outdated. I think it will be just fine and if not I am only out $60 :)
  • marvda1
    marvda1 Posts: 4,951
    i've got one and love the way it sounds. right now only listening through coaxial input.
    Puritan PSM156
  • marvda1 wrote: »
    Does the build quality seem adequate? I have read mixed reviews on that aspect.
    It seems to be a good deal at $250, however.
  • marvda1
    they put the quality into the dac, but once you hook it up and just listen to music you forget about it.
    Puritan PSM156
  • Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
  • No hi rez...bummer, I don't think I could live without that.
  • WagnerRC
    WagnerRC Posts: 2,205
    I picked this one up for 375.00
    https://www.audiogon.com/listings/da-converters-musical-fidelity-m1-dac-2016-01-16-digital-55364-mound-mn?show_listing=true
    Not sure how it will compare with the dac in my M6si
    This one is going on the M6500
    I should have it Monday. I really like all the input options
    tonyb Posts: 33,072
    edited January 2016
    WagnerRC wrote: »
    Should be close Bob, I believe MF used the same dac components from the M1 into the M-integrateds.
  • WagnerRC
    Thank you Tony. I appreciate that.
  • jeremymarcinko
    edited January 2016
    Zdac for $225...a good deal?https://www.audiogon.com/listings/da-converters-parasound-zdac-2016-01-21-digital-94104-san-francisco-ca
    Would you buy from a seller with no feedback?
    Post edited by jeremymarcinko on
  • ukcolin99
    ukcolin99 Posts: 286
    [quote You you buy from a seller with no feedback?[/quote]
    Life's too short.
  • WagnerRC
    at that dollar amount yes. Everyone has to start somewhere. Audiogon staff are very helpful if there is an issue.
  • jeremymarcinko
    edited January 2016
    The Marantz arrived in excellent condition :)
  • Well after reading dozens of reviews I have decided to try the Musical fidelity v90. It should be here Monday. I like it's basic features and 32 bit capabilities. Not sold on burr brown though..fingers crossed. Now to find a another power amp.
    tonyb Posts: 33,072
    Should have gone straight for the M1 in MF dacs. The V90 just isn't up to par in my book.
  • mantis
    mantis Posts: 17,424
    I like the Cambridge DAC's personally over the other 2.
    Dan
  • Yeah, maybe so. I decided on cost and function. The opinions here and elsewhere are very mixed, so it seems to me that preference in Dac s are like preference in women. If I don't like the v90 I'll try something else.
    I think I would have liked the Cambridge too. My experience with Wolfson dacs have been very good. Variety is the spice of life, however. :)
