Quick connects for MW and tweeter harnesses
RandyCroissant
I am gathering parts to finish my 2B upgrade, part of the upgrade is to build new harnesses for the drivers. So far I have Belden Brilliance 16 gauge wire however I am not sure about the size of the disconnects I believe they are .187 and .110 so I bought some Dorman Audio grade gold over copper in those two sizes is that a good choice? and are those the right sizes? thanks...
Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub
I believe the big ones are 0.250" not 0.187"“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
believe you are correct Mr. Gimpod
Thank You!!! I'll get the .250 size by the way are the Dorman terminals any good?Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
.250 is too large. It will fit the spade on the woofers, but will have a lot of slack.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Randy the first .187 and .110 is CORRECT I just checked those I bought two years ago yes they are gold plated Dorman. Sorry for the confusion.
No problem!!! Thanks for the update. Now I just need the spikes and I am good go.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Part numbers? Source?Randy the first .187 and .110 is CORRECT I just checked those I bought two years ago yes they are gold plated Dorman. Sorry for the confusion.
The part numbers are 84546 for the .187 and 84547 for the.110 they come in a ten pack and are reasonably priced. I bought mine at Autozone.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Autozone and advanced auto is where I sourced mine...car audio section.
