The TL Trifecta
Picked these beasts up on Saturday to complete my Sda tl series collection and I didn't realize how big these were till I got them in the same room with the 2.3tl's.I think I can see now why the wife was not to pleased.
I spent most of the day Saturday cleaning them up and massaging out 3 dented dust caps and then pulling all the drivers to make sure they are correct.This should be a fun upgrade but I can see the money flying out of my wallet as I type.
I cant wait to move them over to where the 2.3tl's are and give them a good listening to and compare them to the modded 2,3's but that is a whole day ordeal with the size of these things.e0s7pio3210c.jpg
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • xjghost
    xjghost Posts: 1,115
    Nice! Congrats! One day I hope to have some of those in my listening room..... Got to get the listening room first though.....
    HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
    Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
    Additional projects: RTA 12c's
  • dkfreebird
    dkfreebird Posts: 1,186
    That will be my next goal.I have the room for them now but it is not ideal.We will make our final house payment in two months and will be debt free in 3 more and then I can work on the best room for that.
    xjghost wrote: »
    Oppo 103
    Pangea PC
  • Congratulations!
    Those look like they are in great shape!
  • dkfreebird
    They are in great shape but could use refinishing on the tops.Can anyone point me to a thread that covers that process and also how to take the side trim off?
    Oppo 103
    Pangea PC
  • dkfreebird
    Yep Figured that would be the answer,I have been doing some digging and see the ones about stain removals. I want to redo all of them and just don't know what to sand them down with( and how far) and what stain to use.They are the walnut finish.
    Oppo 103
    Pangea PC
  • dkfreebird
    Oppo 103
    Pangea PC
    gudnoyez Posts: 8,159
    Wow congrats that tops my SDA trifecta, besides your 3.1 and your 2.3 what other TL do you own?
  • dkfreebird
    I just picked up these 1.2tl's a few days ago.
    Oppo 103
    Pangea PC
  • Rex81
    Rex81 Posts: 193
    I'm not a SRS expert (just picked up my first pair this week), but I do a lot of refinishing of speaker cabinets. Totally up to you, but I don't think you need to refinish those at all. They look really clean to me. The finish is good, it's just a little dried out.
    My recommendation is save yourself some money and about 4 hours of your time and simply use two products that I swear by.
    1. Liberally apply Howard's Restore-A-Finish in the Mahogany tone with #0000 steel wool. Use a medium amount of pressure, with the grain. Not like you're sanding with it, but don't be afraid to make some contact. This will buff out that light scratch and fill in the grey toned wood. Once it's all applied, rub it down with a rag or towel to get any residual oil.
    2. After 30 minutes, apply Howard's Feed-N-Wax, again liberally, in a circular motion, to all the wood you just applied the finish to. If your SRS were like mine, the wood will soak this stuff right up. Once you have a nice coat on there, wait 20 minutes, then come back and remove the excess.
    With $15 in materials and 15 minutes of labor, I guarantee those things will shine like new. And smell good too!
  • DarqueKnight
    DarqueKnight Posts: 6,765
    dkfreebird wrote: »
    Congrats on your purchase.
    This thread discusses it, unfortunately, the pictures did not carry over with the new forum format.
    http://forum.polkaudio.com/discussion/26036/sda-srs-1-2tl-side-panel-removal
    Figure 11 of this thread shows what the cabinets look like with the side panels and top/bottom caps off:
    http://forum.polkaudio.com/discussion/131134/curly-maple-end-caps-and-side-strips-for-the-sda-srs
  • dkfreebird
    Rex81 wrote: »
    Thanks for the info but if you look at the 2nd pic there is a faint ring on the top and the side of the top on one looks like someone tried to touch it up with to dark of stain.
    dkfreebird wrote: »
    Thanks DK. I looked at the thread and it pretty much explained what I needed to know.I slid a flat scraper in between the sides and can feel the posts that are in the pic.
    Oppo 103
    Pangea PC
  • Rex81
    Rex81 Posts: 193
    edited October 2015
    You're obviously more of a perfectionist than I am. :smiley:
    Restore-A-Finish will remove water rings if applied with the 0000 steel wool. Might not be quite as effective on the touch up spot, though. Good luck with whatever you decide to do!
  • dkfreebird
    Lol,not really a perfectionist but I would like them to look as nice as they can.I have a lot of upgrades to do to them and am going to try to do the cheaper ones first.
    Oppo 103
    Pangea PC
  • dkfreebird
    dkfreebird wrote: »
    Thanks for the links,I used a flat blade and found the posts that it shows.That will make it easier to break them down.
    Oppo 103
    Pangea PC
  • PolkieMan
    PolkieMan Posts: 2,446
    Nice! You didn't find those in Texas sonny :-)
  • dkfreebird
    I actually picked them up less than 5 miles from the house.The 2.3tl's were about a mile away and the 3.1's were about 15 miles away.I've been real lucky finding them so close to the house. B)
    Oppo 103
    Pangea PC
