Amplifier for SDA 2B's
  • Nightfall
    Nightfall Posts: 10,084
    You'll find the cost of a failed repair and new tweeters even more expensive. If you are unsuccessful with the repair, of course.
    Perhaps look for a used working original?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • I have found a local add with the following tweeter models:
    - Db3000
    - Dx3000
    Will any of this work with my SDAs?
  • I believe both of those are car tweeters, so not compatible at all. You want either a used SL2000 or a new pair of RDO-194s (which would sound better).
    mirceasy wrote: »
    - Db3000
    - Dx3000
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • You can find the SL2000s on Ebay
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • JNinja
    JNinja Posts: 100
    Over and over again, it seems you keep mistake a pre-amp with an amp. I agree with what several others have already said- you are under powering these speakers- horribly. And stop mentioning other brand/models- again as others have said for tweeter replacements you Need SLs or RDO198s...headache
  • leftwinger57
    leftwinger57 Posts: 2,917
    Mirceasy, you will not get by w/ just an AVR for 2Bs. I've told this story many times and I went out and got a Yamaha RX-V665 90wpc. Well it's not measured like that and when just using it as an AVR I was very disappointed, the thing clipped,went into protection mode and thankfully came back. I did have pre-outs on this AVR and under the tutelage of people here in the know said to get a common ground separate power amplifier w/ more than 100wpc. I wound up w/ an Adcom GFA-555 w/ 200wpc and made the Yamaha the pre/amp before I totally went to 2 chl. Any of your AVR choices should have pre-outs for this purpose and you will have enough power to do your H/T thing and have an option to go 2 chl. There are many amps out there and my source after hearing from these guys was to go w/ the Adcom for $300 from Audio Classics which came extremely clean and w/ a spec sheet that gave it a better rating than factory specs. 205a side.
    No affiliation just a customer based on reputation alone. As for tweeters going from SilverDome SL2000s to RDO-194s was an easy, inexpensive, and rewarding mod to do.
  • I managed to recoil the broken tweeter without noticing any obvious sound quality diferences between the formerly broken and the good one.
    Even though I bought the Denon i still searched through the used amps adds every day.
    Now I have the possiblity of buyng one of the two Carver amps :) at approximately the same price :
    - M-1.0t
    Or
    - A-400x
    Which one whould you recommend for powering my SDA's and be used with the Denon preamp?
    pitdogg2 Posts: 27,047
    A-400 only because it is 10 yrs newer.
  • Personally I would keep looking.
    – Kevin Alfred Strom
    tonyb Posts: 33,072
    mirceasy wrote: »
    Unfortunately, where I live (Europe - Ro) the amps market offer is pretty limited. I can find mostly german and japanese hardware. Also the available budget is around 100-150 bucks.
    Given this speakers should I look more for vintage (20-25 years old) amps/int amps/receivers?
    Not much of a budget. Europe is loaded with used gear, but not at that budget for amps. You might consider selling them if you can't afford to fix them or power them, and buy an 8 ohm speaker that will easily be driven by most receivers.
