Pioneer N50
deronb1
deronb1 Posts: 5,021
Just pulled the trigger on this network streamer. Anyone have experience with one. Has good reviews and the price was right, but primary sources are always the best.
  • erniejade
    erniejade Posts: 6,321
    I have not but looked at them and they do look like a good unit. I look forward to your review.
  • deronb1
    Supposed to arrive May 8. Will post my impressions
  • DaveHo
    DaveHo Posts: 3,583
    I've been using one for a few weeks now. My use case may not be typical, I am feeding the optical out to my pioneer sc1523 for the main zone & the DAC output also goes to the receiver for zone two. The receiver already had streaming capability and sounds identical being fed the optical output from the n50. The analog out for zone 2 seems a bit stronger in the bass but this is zone2 so I'm not overly critical for that purpose. Really the only thing the n50 got me was the ability to shuffle, which I always use for zone 2. Ironically the shuffle capability is the source of the only complaint I have. When you power down the n50 it doesn't retain the shuffle setting and the android app doesn't have the ability to turn it on. Oh, the the front panel display is useless unless you are sitting within a couple of feet of it, but you probably already knew that if you did any research on it. BTW, I'm streaming flac ripped from CDs. I've also used the internet radio some and like it.
    -Dave
  • deronb1
    Thanks Dave. Im gonna have a 2TB hard drive hooked up to it via USB A. Will probably use the Pio dac instead of Onk dac, so analog out
    Will the android app work without the optional wi-fi adapter?
  • mantis
    mantis Posts: 17,383
    I've been eyeing this up for a while but haven't had the time to dig into it.
    Dan
  • deronb1
    mantis wrote: »
    Lots of positive reviews. Should be here Friday. Ill post some comments a few days after.
  • DaveHo
    DaveHo Posts: 3,583
    edited May 2015
    deronb1 wrote: »
    You need to connect it to your network in some fashion for the android or iphone app to work. If you connect it via ethernet, then you will not need the wi-fi adapter. This is how mine it set-up.
    By Onk dac do you mean the dac in your receiver/processor? Will you be using the bass management in the Onk while using the N50 as a source? If you feed the Onk analog from the N50 & use the Onk's bass management, you will be introducing a pair of A2D & D2A conversions since the Onk will take that analog signal & convert it to digital to do bass management then back to analog. If that is your plan you'd be better off just feeding the Onk a digital signal from the N50.
  • deronb1
    Ok. Thanks. I will try both methods and see which sounds best.
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2015
    I wish the HDD USB connector was in back. I have be eyeing this unit as well as the CA Magic Stream 6 v.2.
    This highlights the Oppos MAJOR strength; no need for a network at all if you connect a HDD loaded with music. Nor do you need an app, as your HDTV IS your interface/display.
  • deronb1
    I dont really want to have my tv on every time i listen to it. Thats what so appealing about the app. No chance to go eithernet, so guess ill have to get the wi-fi adapter.
  • mantis
    steveinaz wrote: »
    Yeah I looked into that as well as the Sony HAP which I had here for a in home demo. Fantastic piece by the way.
    NAD also has one that I have access to which I want to bring home.
    Dan
  • erniejade
    Agree on the Sony. I almost pulled the trigger several times on it after a weekend in home trial.
  • DaveHo
    DaveHo Posts: 3,583
    deronb1 wrote: »
    I know the N50 is already on the way, but did you consider the Marantz NA6005? It has built in wi-fi, does DSD, & is a second generation design. I didn't need either of those, but if I did I probably would have gone with the Marantz as once you figure in the cost of the wi-fi adapter the gap in price begins to shrink. Not to mention the Pioneer wi-fi adapter does not have a very good rep for working well.
  • deronb1
    Is there such a thing as a usb b 3.0 to usb b 2.0 cable?
  • deronb1
    Pioneer cs sucks. Been on hold for over 47 min
  • deronb1
    Dont think this unit can accept an external hard drive. Gonna send it back.
  • erniejade
    Or does it not see a usb 3.0?
  • deronb1
    erniejade wrote: »
    Not really sure. The manual doesnt get into that. I waited for over an hour to speak with someone from Pioneer before i hung up.
    The manual does say that the unit does not support an external hard drive. I found where it does with firmware updates, but really dont want to mess with it.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Give the firmware updates a shot. I remember all the BS I had to go through before my Stream Magic 6 did everything I wanted it to do, and now it is so smooth. I'll bet the Pio will be great, just may need some love. And customer service departments all have busy times so these things take patience........I know right?? Just saying, don't give up until you try all options.
  • deronb1
    It says i need a flash drive formatted to FAT 32 with no other files on it. Then have to download the file, unzip it and intall it in the Pio. Not sure if i can do all that
  • tophatjohnny
    deronb1 wrote: »
    You can brother. I know you can!!!
  • DaveHo
    DaveHo Posts: 3,583
    I did the firmware update when I got mine. It's not as hard as it sounds. You can do it!
    However, I'm not sure you really need the firmware update to use an external hard drive. But, the hard drive does need to be formatted FAT32. NTFS will not work.
  • steveinaz
    You are using the front panel USB input, correct? Some streamers also require hard drives that are "powered" with an ac/dc adapter. Does your HD have it's own power cable?
  • tophatjohnny
    steveinaz wrote: »
    His HD does have its own power cable and is formatted to FAT32. It's ready to roll. Just needs that update I'm thinking.
  • steveinaz
    Cool then, he needs to learn how to do firmware updates anyway. Rock on...
  • erniejade
    People still use fat32? Everyting I own and at the company I work for uses NTFS. Heck even my previous job they used ntfs. Can the streamer not see ntfs? or is it just fat 32 for that usb stick?
  • deronb1
    Ok, so it will read music on a thumb drive but still not the ext hard drive. The hard drive is FAT32. According to the manual, i need a usb a to usb b 2.0 cable, which i do not have, to do the update. Also, my computer is upstairs and the unit is downstairs. I didnt plan on hooking it up to a network or anything. Also found out that i need the wi fi adapter to use the android app.
    Dont think this is the unit i am looking for. I can return it, but will cost 15% restock plus ship back.
    On a positive note, it did sound very good with music on a thumb drive played through it.
    If anyone is thinking of buying one and plans on hooking up to their network, this one is officially for sale. 300.00 shipped to your door. 310.00 if using paypal.
  • erniejade
    I have plenty of usb 2.0 cables. I can mail you one.
    Or they are usually 2-5$ at the store.
  • deronb1
    Thanks. Ill go pick one up.
