dbPoweramp & uncompressed flac question?
gimpod
gimpod Posts: 1,793
I have ripped over 500 CDs to uncompressed flac with very good results for the most part, but I am having one problem and that is the break between the tracks or in the case of cds like Pink Floyd cds the lack of. If I convert to flac the break is there (wrong, it's not suppose to be there), If I convert the same file to uncompressed wav the break is not there.
My question is, can this behavior in flac be turned off and if so how ?
P.S. I don't care about drive space at 12TB's I don't think I'll be running low for awhile.
  • nspindel
    nspindel Posts: 5,343
    I don't think its the flac itself, more likely it's the software that is playing it. Try playing in foobar 2000 and see how it sounds.
  • gimpod
    gimpod Posts: 1,793
    That was it, but I don't like foobar 2000. I guess the codecs for WMP can't keep up so I'll keep looking something else.
  • nspindel
    Well glad you at least got to the root of the problem. I don't use the computer as my player, I use a squeezebox.
  • D'prived
    D'prived Posts: 191
    Whatever you use to play the FLAC files has to support gapless playback.
  • bikerboy
    bikerboy Posts: 1,232
    Try Jriver. Great media player.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
