Sending very large files
I have a 30GB file I need to send to someone, via email or a link. I've heard of DropBox but don't know if that will work, anyone have any suggestions?
  • Mikey081057
    Mikey081057 Posts: 7,127
    Can you zip it? I don't think the free version of dropbox will let you store 30Gb.. you'd have to go to pro and commit to prob 15 bucks a month... try winzip but whoever you are sending it to will also have to be able to receive a big file... easy to put it on a thumb drive and ship to him
    Garage | Polk Monitor 5B's
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    I have the option of mailing as a last resort, was hoping for something quicker. I don't think this will compress much with a zip but will look at it.
  • mrloren
    mrloren Posts: 2,474
    anything over 2gb chunks is hard to send without an FTP site. Best bet is to flash drive it and snail mail. If you have Cox or Road Runner you could split it into small 4gb files and use the cloud.
  • BlueFox
    BlueFox Posts: 15,251
    Create a dir, make it a private share, put the file there, and let the recipient map to it, and copy the file. Of course, that requires a lot of configuring, but it should work. Google should be able to help.
  • AsSiMiLaTeD
    I"m not trying to share the file on my network, looking for a service that will allow me to SEND the file to someone else, kinda like a giant email attachment.
  • AsSiMiLaTeD
    Thanks guys, I'm aware of the existence of a service called the mail that would allow me to physically send the file :-)
    I was hoping there would be a service that would work for me.
  • BlueFox
    I meant share it over the Internet, not share it on your home network. It's doable, but I don't know how to configure the router to allow your computer to be seen by the other person.
    Also, I think you can use the Bit Torrant software and distribute it that way, or some other file sharing software like original Napster.
    However, is there a file size attachment limitation with Yahoo mail, or Gmail. I know our work email is limited, but that is because IT set the upper limit. Technically, any size should work.
  • westmassguy
    westmassguy Posts: 6,850
    WinRAR and WinZip will allow you to compress and split the file into smaller parts, called a file set. The smaller files can be emailed. Once all the files are received, they can be extracted/decompressed using WinRAR or WinZip. WinRAR can handle Zip, but not sure if WinZip will handle RAR files.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • gimpod
    gimpod Posts: 1,793
    Not a bad idea if the file was a lot smaller. They say 10MB is max size for e-mail, I never been able to send anything larger than 5 MB, also because e-mails are mine encoded they end up being about %33 larger. At 30 GB not very practical, that could be more than 300+ e-mails.
    At 30 GB I think upload/download service could take hours, if it's not copyrighted stuff.
    I think a 32GB USB Flash Drive would be you best bet there cheap and just mail it.
    JMO.
  • westmassguy
    You could also split it with WinRAR into 4GB files, and burn them to DVD, then send the DVDs
    msg Posts: 10,452
    edited December 2014
    it might have been mentioned already, but have you considered UPS/Fedex'ing your computer to the person? just a thought...
    seriously though, the bittorrent idea is pretty good. and/or, also the regular file sharing over the internet, set your firewall to allow only this person's IP, though, and fwd the port to your host computer. then have the guy grab Free Download Manager and start pulling the file over. it supports resuming in case of dropped connections. you might also try incorporating the WinRAR option, but choose store/no compression, just to break it up in to more manageable pieces.
  • rooftop59
    rooftop59 Posts: 8,121
    google drive is only 1.99 a month for 100 gb, and you can share with anyone. Cheapest option by far. This is what I use for the classes that I team teach. We share everything from video files to large powerpoints with embedded video etc. Should work fine. You can sign up and cancel if you do not want to keep it.
    HA. just realized that this is over a month old. You could have rode a mule and gotten it there by now ;-)
    Game Room 5.1.4:
    Bedroom 2.1
    msg Posts: 10,452
    haha, yeah, I didn't pay attention to that either - I just hopped on after the last guys. guess we were desperate for content, haha :)
    Google Drive was the best idea by far, imo - dehr - we even use it for work.
