Cambridge Audio 840e
Is it a general rule (if there is such) that if the pre out RCA's don't seem to be working (the xlr pre outs won't work either??? Having a tough go if it here!!
Best Answer
  • mantis
    mantis Posts: 17,611
    Answer ✓
    No You can have broken one or the other or both. Send it to Cambridge , they have a wonderful technical staff there, they will get it working for yeah.
    Dan
Answers
    Didn't you buy that used ? Call the seller and see if you can get your money back.
    On a side note, how do you have it hooked up ?
    SCompRacer Posts: 9,152
    edited October 2014
    Which inputs are you using? If 1 or 2, do you have the switch set to proper input (balanced/unbalanced)? If you can adjust different volume per input, make sure the input you are using is not muted.
    If all else fails, does it have a factory reset to return it to default settings?
  • tophatjohnny
    tophatjohnny Posts: 4,189
    After trying the XLR's with same result I ended up sending the pre to PBN audio. Peter has been very good to me and I am in hopes he can get it back to me in working order.
