Power Amp for LSiM705
Need to get a power amplifier for LSiM705. Current options are Parasound 2250 v2 or Emotiva XPA 2 Gen2. Any recommendations between these two? Thank you in advance.
Parasound
Seconded.Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
I vote Emo. Newer. Had the Gen 1 and it was a great amp. Have owned Parasound too and it's also great stuff.
Emo is more on the bright side but NOT harsh like a lot of guys claim. -
audiocr381ve wrote: »Emo is more on the bright side but NOT harsh like a lot of guys claim.
To who's ears? Sound is subjective, and to many here the XPA series is akin to nails on a chalkboard, depending on the speakers used... I have heard an XPA-1 on a set of Maggie 3.7's recently and the ribbons even sounded bright to my ears.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »To who's ears? Sound is subjective, and to many here the XPA series is akin to nails on a chalkboard, depending on the speakers used... I have heard an XPA-1 on a set of Maggie 3.7's recently and the ribbons even sounded bright to my ears.
Sure and yes sound is subjective. Nails on a chalkboard? Crazy talk. -
XPA-200, XPA-500, XPA-5 all sounded harsh to me with Monitor Series II (60s, 70s, CS1 and 30s) and LSis.
The XPR-5 I have now on the other hand is a WHOLE other animal. For the price I paid, I would be hard pressed to beat it. But there are better options out there than the XPAs. Again, IMHO.
I respect that. -
So the general consensus is Parasound 2250? I also have the option of the NAD C275 but thats a couple of hundred more than the Parasound and is rated at only 150x2 into 8 ohm.
Parasound all day and twice on Sunday.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Emotiva all day and three times on Sunday. Get yourself a warranty & buy new, you deserve it.
If a new amp still works after the first day the likelyhood that it will need repair under warranty is damn close to nil, so buying a new amp for the warranty is not a reason to do so. Buying a good condition used amp and getting a much better one than you could afford new is a reason to do so.
Wasn't listed as as option but:
TOOBS!My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Sure but where we're disagreeing is whether the Parasound is better. Different, sure. Better, I disagree but respect your opinion. -
You may be happy with either the Parasound or Emotiva in my opinion. Emotiva apparently fixed a concern I had with their first generation XPA amps with their Gen 2 versions, which was to reduce the noise floor by reducing the gain. I haven't heard a Gen 2 amp from them to see if their changes really worked. If you're using an amp primarily for home theater I'd go with whatever is cheaper. -
Oh Jesus, no no no, not another emotiva fight...Up
Down
Inspector 24 wrote: »Oh Jesus, no no no, not another emotiva fight...
Oh no, someone trying to make something of nothing. -
Ha! I've been on this board long enough and have seen a few start out this simply, as have seen similar situations about other subjects on other boards. The feels always run strong and deep in both camps.
I say listen to all the experiences and do what works for your needs, ears and budget.Up
Down
Inspector 24 wrote: »Ha! I've been on this board long enough and have seen a few start out this simply, as have seen similar situations about other subjects on other boards. The feels always run strong and deep in both camps.
And I would agree with you
Thanks guys. Dont really want to start a fight. Dont have the chance to listen to the amplifiers before purchase therefore the queston.
Between Parasound 2250 v2 (275x2) and NAD C275 BEE (150x2) does anyone have first-hand knowledge which would be better? The drawback I see is the low watt rating of the NAD. -
Parasound....and dont look back.HT SYSTEM-
lsi 9's -
what price range are these amps in?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Emotiva XPA-2 $899what price range are these amps in?
Parasound 2250 $1098
NAD C275 $1250
Plus shipping -
ureka3 - what preamp are you using now?
My Denon 3312 will be doing the preamp duties.Erik Tracy wrote: »ureka3 - what preamp are you using now? -
Wyred 4 sound st 500
Having had a Parasound, I would go with that, but I also wouldn't hesitate with the Emotiva either since it is brand new with a warrenty if you feel more comfortable with having that. But this gear is built to last for years so you can't go wrong either way.
Welcome to Club Polk Ureka!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
polkfarmboy wrote: »Wyred 4 sound st 500
+1. I own the 1st gen. Parasound 2250 and the Wyred 4 Sound bigger brother of the ST500 in the multi-channel version. I don't think you can go wrong with either. It will be a long time before the Wyred leaves my system._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
I remember you not liking your W4S amp? -
How about a classic Bedini, high current ampMain System- Scratch built 2A3 , Lightspeed preamp, Technics SP15/Graham/XV1s,Klipschorns w/ALK xovers/Trachorns, Speakercraft MT8(4), Sonos ZP90, Yamaha Aventage for surround
Office System- Adcom GTP500, Bedini 45/45,Lexicon RT-20,Enlightened Audio DAC, Polk SDA2.3TL, Northcreek Borealis
