How to get USB Audio Support on my Nexus 5?
DaveHo
DaveHo Posts: 3,583
edited March 2014 in Going Digital
Just picked up a Google Nexus 5 phone. It appears it can output audio via USB, but not without some work. Question is, which route should I take? Keep in mind I'm a newb when it comes to rooting phones & stuff like that.
The easy way it appears would be to install USB Audio Player Pro. I've read mixed reviews on the usability of the app. Anybody use it? Secondly, I could install CyanogenMod 11 in place of the Google OS. Frankly , never having rooted a phone before this option is kind of intimidating. Are there any other options I'm missing?
The end application is to use my phone & a USB DAC to feed my Schitt Asgard 2 headphone amp in my work rig.
Help!
-Dave
Post edited by DaveHo on
    EndersShadow Posts: 17,726
    edited March 2014
    Honestly at this point I personally gave up trying on my HTC One. In the long run, your source files are not super good (unless your using FLAC that is), so the difference between line level and the phones DAC and a good USB DAC can only help it so much.
    I am just looking at getting a JDSLabs C182 so its super portable (I get up from my desk a lot) and calling it a day.
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2014
    See, that's the thing. I am using Flac, & I'd like to get the best I can out of it. It'd be nice to at least be able to compare for starters.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited March 2014
    Rooting and installing custom roms on the Nexus 5 is easy! Read up on xda forums. Always be sure to backup important stuff along the way. You can always go back to stock if you don't like the results, but after flashing a few roms, I doubt you will!
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2014
    Keep in mind that not all USB DACs will work with a phone, which DAC are you looking at?
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2014
    Needs to be a powered dac,correct? Haven't really narrowed it down yet, but was considering the Topping D20 because it's cheap & seems to have some proponents over @ headfi. I see you have the DAC itx. That's also in the running.
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2014
    I have an HRT Microstreamer that I user with my Note 3; it works well w/ the stock music player and can run with or without any external power. So far I've been pretty happy with it (use it in the car & work mostly).
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
