Remote control
Mark002
Mark002 Posts: 1
edited February 2014 in Troubleshooting
I have a Soundbar 6000, My remote control only works occasionally, I have had the battery tested and that is fine. What could the issue be.
Thank you.
Post edited by Mark002 on
  • mantis
    mantis Posts: 17,502
    Sunlight will stop IR signals , you could have some interference. Or you simply could have a remote going bad.
    Dan
  • Zentish
    Zentish Posts: 127
    CFL bulbs will also wreak havoc with IR remotes. Test this by turning the light off and seeing if the remote works.
    Receiver: ONKYO TX-NR929 7.1 AVR 130wpc
    Mains: 2x Polk RTA 8TL's
    Center: Polk CS245i
    Surrounds: 2x Klipsch RS-41ii (because they fit perfectly over the door and window)
    Rear Surr: 2x Polk M4a '90
    Subwoofer: Speakerlab DAS-SW dual-voice-coil 10" '88 30Hz-150Hz
    Subwoofer Amp: ONKYO A-8019 AMP '85 100wpc
    Display: Samsung 55" UNC55-8000 3D LED
    Console: Xbox360
    DVR: custom MythTV rig w/ 3 tuners OTA
    Zone2: 2x Polk M5b '87
