ar
2-tall
I have an old AR XA turntable that still sounds great.I am wondering if i should put new cables on it going to my amp.Has anyone done this on a table?Does it help with the sound?Any ideas what to use?
Thanks,
2-tall
Thanks,
2-tall
Post edited by 2-tall on
Instead of replacing the cables with other cables, you might want to consider replacing the original cables with RCA jacks. That way you can try different interconnects.
I removed the cables that were permanently attatched to my Yamaha PF-800 turntable and replaced them with heavy duty Cardas RCA jacks. The Monster cables I currently use provide significantly more resolution than the stock cables.Proud and loyal citizen of the Digital Domain and Solid State Country!
