Best Docking Station For the iPhone
PreCd
PreCd Posts: 786
edited December 2013 in Music & Movies
I want to get my daughter a docking station for her iPhone. What do all of you like out there? Would like to keep it under $200 if possible.
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Post edited by PreCd on
  • steveinaz
    steveinaz Posts: 19,545
    I bought a Phillips brand for my wifes Droid---they also make an iphone version, I believe it was $67 bucks thru Amazon.
  • StantonZ
    StantonZ Posts: 452
    What do you want to do with it? Just charge? Connect to a home stereo (high or low-quality)? Depending on what you want to do, you could just buy a $10 cable or a $300 DAC.
    (2) Polk RC80i (Top Middle)
    Polk CS300 center channel
  • cfrizz
    cfrizz Posts: 13,415
  • zane77
    zane77 Posts: 1,696
    I got my wife a Sony, similar to what Cathy shows, but with a 30 pin connector for her 4S. It works pretty well but if you aren't interested in charging at the same time a Bluetooth speaker is very nice.
    Two Channel
  • mantis
    mantis Posts: 17,411
    check out the home line
    http://www.ihomeaudio.com
    Dan
  • PreCd
    PreCd Posts: 786
    Thank you all for the suggestions. I did not think of a Bluetooth speaker. If the unit does not have a remote that would be good to have. Any other opinions from anyone is appreciated especially those who actively listen to a docking station.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • rooftop59
    rooftop59 Posts: 8,121
    Again, what is it for? For background music in a bedroom or back porch? Do you want it to fill a large room? I take it that you do NOT want to connect it to a home theater or other sound system??
    I have this one for an alarm clock: http://www.ihomeaudio.com/iP21GVC/
    Its fine for waking up to or for podcasts, but I wouldn't listen to music on it.
    Game Room 5.1.4:
    Bedroom 2.1
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    Yep, we need more info on what you want to do.
  • PreCd
    PreCd Posts: 786
    The docking station will be used in a room approximately 10x12. I would like it to charge but connection to another device such as a receiver or television is not necessary.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • AsSiMiLaTeD
    So are you wanting something with a speaker built in? You may want to look at the Polk dock and see if that meets your needs. If you want something with Bluetooth the Peachtree DeepBlue is an amazing product.
  • PreCd
    PreCd Posts: 786
    Thanks assimilated but I posted that I really wanted to stay under the $200 mark. And yes speaker built in. Thanks for the options.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • AsSiMiLaTeD
    If you can stretch your budget by $25 Polk has an ISonic on their ebay store
  • PSOVLSK
    PSOVLSK Posts: 5,382
    http://www.amazon.com/Altec-Lansing-iMT630-Portable-iPhone/dp/B005IVL0UA/ref=sr_1_8?s=electronics&ie=UTF8&qid=1386471522&sr=1-8&keywords=altec+docking+station
    I have one of these that I ended up not using like I thought I would. I'll sell it cheap and you can get her something else with the money you save:)
    Not a bad little unit. There are better out there, but for a 10x12 room this would do the job.
  • PreCd
    PreCd Posts: 786
    I have beat this to death the last few days and it looks like most of the units I have seen that are in the upper end as far as listening is concerned takes a lightning connector. So here is what I am looking hard at: http://fluance.com/product/Two_way_High_Performance_Wood_Speaker_Dock_Music_System_for_iPod_iPhone.eng-8.html
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • rooftop59
    As other have mentioned, if you are going that high anyway I would seriously consider pushing it 25 bucks more and getting this: http://www.ebay.com/itm/I-Sonic-ES2-HD-Table-Top-Radio-iPod-Dock-Polk-Audio-/231070013164?pt=US_Digital_Clocks_Clock_Radios&hash=item35ccd896ec
    Polk makes great sounding products for the price. Fluance is a much more budget product generally. But I agree it looks nice. Ideally you hear them next to each other, but i realize that's probably not going to happen. good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • PreCd
    PreCd Posts: 786
    That is a nice model it seems. By the way the look of that unit is not what got my attention but the rave reviews it got from uses and other sources. And I can get the Fluance product from eBay for $149 shipped.
    This is why I love 2-Channel vintage audio..........it makes things so much more simple. However I can't get her to put a tube amp and 70lbs. speakers in her room. :-)
    Thank you for the post, I appreciate it.
    rooftop59 wrote: »
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • rooftop59
    PreCd wrote: »
    Funny, I was going to suggest something like that. :lol:
    Before you pull the trigger, what about these? Its isn't a dock, but she could have it charging and use the headphone out to run to the speakers:
    http://www.amazon.com/M-Audio-BX5-D2-Monitor-Speakers/dp/B005F3H6Q8/ref=pd_cp_MI_2
    Game Room 5.1.4:
    Bedroom 2.1
    txcoastal1 Posts: 13,513
    Make sure what ever your choice is that it matches your Iphone adapter via it be I4 or I5 connection
