Synergistic Research Fuses installed tonight
    VR3 Posts: 29,429
    edited September 2022
    I bought the synergistic fuses a while back, I pulled back the sticker and it revealed a 75 cent fuse was used... Beyond dabbing it with black paint and I installing a sticker on it, I could not see how they otherwise altered it.
    I went with hifi research fuse which was an actual fuse built from the ground up with silver and gold caps, silver fuse lead, etc...
    Heard minimal to no differences.
    Caveat emptor as always in this hobby
    https://forum.polkaudio.com/discussion/194604/synergistic-research-orange-fuses#latest
    msg Posts: 10,452
    I've tried removing the fuses in my amps and backgrounds are definitely quieter.
    still waters run deep
    :smiley:
    It is unknown whether they make sound in the forest.
  • jdjohn
    jdjohn Posts: 3,357
    I've kept the Tweek Geek website (with Quantum Science Audio products) open as separate tab in the background for awhile now. There are reviews that say the QSA fuses best the SR fuses, but no personal experience here.
    audioluvr Posts: 5,916
    HiFi Research fuses are awesome!
  • Should I even ask what the theory is behind this since the ear is the best measuring instrument, although subjective?
    All I know is that different alloys have different melting points. Heat dissipated by the filament = I^2 x R and if I is high enough the temperature resulting will melt the filament. R increases with current and temperature = positive temperature coefficient. I would think for stable audio over different listening levels you would want this PTC to be as low as possible.
    So it all comes back to the idea that different metallic compositions and grain structures (cryo treatment effects this?) sound different but this cannot be measured? Yet.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    treitz3 Posts: 19,992
    ~ Not all things that can be measured can be heard and not all things heard can be measured ~
    VR3 Posts: 29,429
    In my experience with fuses, you should take your old fuse out, clean the contacts then put it back in.
    After listening to that, try the new fuse
    Always.
  • The SR fuses are not impressive looking at all. They inspire no confidence (especially relative to the price). As VR3 wrote above they look like the crappiest fuse you could buy with a sticker and a dab of some mystery substance. I have little understanding of what sort of voodoo SR claims to perform on them. One would think that for what they charge, SR could start from scratch with OCC copper or silver caps; the very best materials obtainable. However, as posted earlier, they were a vast improvement on the HiFi Tuning fuses (everything polished and treated with DeoxIT Gold) in my Cambridge 840C. I install the same SR fuse in my Ayre preamp - nothing.
    VR3 Posts: 29,429
    Synergistic research as a company is caveat emptor. Ted genny or whatever his name is is a real piece of work.
    Feel free to read into his audioholics shenanigans.
    Buyer beware.
  • Yes, caveat emptor.
    msg Posts: 10,452
    Latin is dead, speak English you freaks.
    Stock fuses are steel wire. Nothing else in the signal path from pre to speaker that I'm aware of is. If it was a great signal transfer medium don't you think there'd be more?
    Edit: maybe signal tubes.
    HiFi Research fuses use silver.
    VR3 Posts: 29,429
    Most cheap caps and resistors use steel leads
    msg Posts: 10,452
    that is kind of a good point about the fuses and their conductors. I never really thought much about these things. I don't know how much the steel leads differ from the conductors' gauge/material and all in the path where the fuses are, but does seem like a choke point?
    VR3 Posts: 29,429
    Hifi tuning Supreme is the ONLY fuse I am aware of that is built from the ground up with copper /silver caps with a silver filament wire.
    Every other brand is taking every day fuses and doing voodoo magic as far as I can recall.
    The real kicker is the hifi tuning fuses are not that expensive compared to the synergistic, etc
  • Fuse filaments are definitely not made of steel because you need a high resistance and low melting point. Something like a Sn, Pb alloy. Ag, Cu, Zn, and Al can also be in the mix.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • invalid
    invalid Posts: 1,456
    Fuse filaments are made of tin and lead as far as I know
  • Also, the HiFi tuning fuses I replaced with SR (post above) were an early non-Supreme version. Have not tried the Supreme version (yet). The description of the Supreme construction sounds impressive.
    I meant to say high resistivity which is resistance per unit length for a given cross sectional area = R x A/l
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    skipshot12 Posts: 1,974
    Ok now….
    Can someone please explain to me how a fuse can change the sound of a component?
    Skip
  • invalid
    A fuse is a bottleneck, also some people claim the vibration through the fuse can be heard. I don't think anyone is arguing that when a fuse is used in a speaker, eliminating it is definitely an improvement in sound quality, also most really high end amplifiers have stopped putting them in the power rails.
  • skipshot12
    Any other splanations would be appreciated.
    I’m having a hard time with this one.
    VR3 Posts: 29,429
    The musical fidelity tri Vista integrated has fuses in line with the main outs. I upgraded those to the hifi tuning Supreme.
    I experienced no real changes upgrading fuses
  • skipshot12
    Tanks guys.
    I’ve been into the tweak/mod gig since coming into this hobby in the 70’s.
    Always trying to eek out a little better sound.
    Even if it didn’t provide an improvement in sound it is always enjoyable fiddling with my gear.
    Building my own speaker wires provided an increase in enjoyment, when listening, just looking at what I had accomplished.
    Other times there was an improvement.
    Very reason I’m enjoying the first set of mods to my sda’s….
