Bit of a debate with a friend...
ZLTFUL
ZLTFUL Posts: 5,655
edited July 2013 in 2 Channel Audio
SO last night I stopped by one of my local audio buddy's house on the way home from work. As we sat around talking audio and drinking a few beers, I noticed that his 2 channel system's speaker cables.
Normally, this would be no big deal but the thing that caught my eye was the fact that he had these home built (Canare) bi-wire cables that were about 25+feet long. The only problem was, his speakers were only about 4 feet from his amp on each side. The remaining wire was then neatly wire-tied into 2 coils. Each coil was nice and tight and about 4 or so inches in diameter.
Now, I argued that he was, in essence, creating an inductor with his speaker wire and with it being part of the signal path, he was probably effecting the sound quality of his system and maybe even drastically.
He argued that the cable "isn't bare so it wouldn't matter".
I am pretty sure that I am right here.
So...am I?
Post edited by ZLTFUL on
    tonyb Posts: 33,001
    edited July 2013
    I would imagine that would depend on the amount of shielding the cable has. Some are better than others in that regard. As long as he likes what he hears and no obvious interference can be heard, not a big deal really.
  • marvda1
    marvda1 Posts: 4,904
    edited July 2013
    it should be easy enough to make two short runs of the same wire, then you both can compare over a few beers:razz:
    another thing to consider is, if the gauge of the wire he is using is right for that length.
    Puritan PSM156
  • zingo
    zingo Posts: 11,258
    edited July 2013
    DSkip wrote: »
    Either way, I bet he'd get better SQ out of it with 6 ft versions instead of 25 ft versions. That's a long run of cable for mains.
    Can't argue with this; shortest length of wire the better. My opinion is since it's important to minimize induction in speaker cables, coiling them cannot help.
  • ZLTFUL
    ZLTFUL Posts: 5,655
    edited July 2013
    zingo wrote: »
    Pretty much what I was saying to my buddy.
    I have a pair of 8ft AQ Flex series based bi-wire cables I may put up for testing with him.
  • Speedskater
    Speedskater Posts: 495
    edited July 2013
    Back to the coil question. Because it's a cable with signal flowing both directions, it doesn't act as an inductor coil.For a coil to work, all the current needs to be going in on direction (clock-wise or counter-clock-wise). Sometimes you hear the urban legend about an AC power extension cord being coiled and then burning-up, well it's not true for the same reason. And even if current was only flowing in one of the extension's wires (making it a real coil) the coil's induction would limit current not encourage it.
  • bmbguy
    bmbguy Posts: 416
    edited July 2013
    Hmm. Inductors seem to work pretty well inside the speaker cabinets -- as part of the crossover network, exposed to the same AC signals.
    tonyb Posts: 33,001
    edited July 2013
    marvda1 wrote: »
    Best advice right here, crack open a few and slip some shorter cables in and see for yourselves. Same type of cable obviously.
  • Systems
    Systems Posts: 14,873
    edited July 2013
    I am from the "shorter is better" camp myself.
    You might have some added resistance at that length (non-issue), and possible added EMI/RFI, but there would be nothing gained by having 25 foot lengths of SC's for a 4 foot run.
    That said you would be lucky to discern a gain in SQ (minor?), without switching to another "brand/design" type.
    I would just bunch the excess wire in a radom pattern, instead of coiling them which is "theoretically" a better idea.
    I had 25 foot runs a couple of years ago, and cut an 8 foot pair off from the same wire, using the exact same system, and could not tell a difference to be honest.
    It was when I went to a different manufacturer, @ 8 foot, that my personal tastes kicked in, and my system sounded better to me.
    Testing
    Testing
    Testing
  • Msabot1
    Msabot1 Posts: 2,098
    edited July 2013
    Short path to anywhere is best...for a induction to work ya need a choke..right? Four inch coils on 25ft seemes tight...how is it shielded and what is the drive?
  • George Grand
    George Grand Posts: 12,258
    edited July 2013
    ZLTFUL wrote: »
    Great AM antennae.
  • Systems
    edited July 2013
    There are alot of cancellation effects in speaker wires, moreso than analog source signals ect.
    Testing
    Testing
    Testing
  • Speedskater
    edited July 2013
    bmbguy wrote: »
    Exactly, but the cross-over inductors don't have both speaker wires going through the coil.
    By the way, if you carefully looped some brands of speaker cables you could make a small coil.
    F1nut Posts: 50,734
    edited July 2013
    I coiled the power cord on a vintage wall clock I have. It ran slow, so I uncoiled the cord and it now keeps the right time. :twisted:
  • Systems
    edited July 2013
    That is directly related to the amount of crystals you have on your pc Jesse.
    Next time order less "crust" and I think you will be shocked at the time it will keep!:lol:
    Testing
    Testing
    Testing
  • ambiophonics
    ambiophonics Posts: 726
    edited July 2013
    Are these alien crystals or the earthly variety?
    2 Channel - Polk SDA-2BTL, Carver TFM-35, Peachtree iDAC, Qobuz streamed via Episode Lynk using bubble UPnP server
  • Systems
    edited July 2013
    Alien.:lol:
    Testing
    Testing
    Testing
  • Systems
    edited July 2013
    Personally I have just not found the "Huge" difference in SC's as I have in source cables.
    Maybe just me and my system/synergy?
    I use Nordost speaker cables and love them, but SC's do not offer the substantial returns IC's do.
    JMHO.:redface:
    Testing
    Testing
    Testing
  • zane77
    zane77 Posts: 1,696
    edited July 2013
    I think taking your shorter cables and a few beers to your buddy's house and a beer side bet could make for an enjoyable evening. Personally I think shorter is better.
    Two Channel
  • Systems
    edited July 2013
    If you start pushing the "50 foot" point you might want to reconsider some design perimeters, but doubt you will hear much difference (if it is less than 50ft) between a 5 foot or 25 foot pair for that matter, if it is the same wire.
    A quick easy tweak you might try is "Uncoil" that wire behind his speakers, and just "wad" it up in a "random lay" as opposed to "coiled" or a "solenoid" type situation.
    You may actually hear a difference there.:cheesygrin:
    Testing
    Testing
    Testing
  • BlueFox
    BlueFox Posts: 15,251
    edited July 2013
    zane77 wrote: »
    That's what women say when they are trying to be nice. :eek:
  • zane77
    zane77 Posts: 1,696
    edited July 2013
    In our MRI and CT systems they come with pre-terminated cables and if they are too long we lay them in the floor troughs in a figure 8 pattern to help eliminate noise problems caused by coiling the wires
    Two Channel
  • boston1450
    boston1450 Posts: 7,668
    edited July 2013
    Would making both speaker wires the same length be a good thing vs different. Ive always made the same lengths no matter what. Maybe im odd ? Some room placements differ
  • Systems
    edited July 2013
    boston1450 wrote: »
    Not a big deal, again, I doubt you could ever hear a difference, that said, I always make mine the same length also.:cheesygrin:
    But I doubt you could ever tell the difference in speaker cables, unless you are talking about "Long Lengths".:mrgreen:
    I keep everything equal, IC's, speaker cables, power cables..ect.
    But as far as speaker cables go, it is not as important.
    Testing
    Testing
    Testing
  • boston1450
    edited July 2013
    Wasnt sure the speed of signal if it would effect it. Probably not to the human ear--thanks
  • Systems
    edited July 2013
    boston1450 wrote: »
    Its just not something you would actually hear as far as speaker cables go.
    However, there is a VERY good chance you could hear a "difference in length" with analog IC's.
    Testing
    Testing
    Testing
  • BlueFox
    edited July 2013
    pepster wrote: »
    There is a VERY good chance you could hear a "difference in length" with analog IC's, but that is a whole different ballgame.
    You guys are pushing reality bounds here. What is a difference in length? 1", 10'? Back to the original issue, 25' of cable when 4' will do is just sloppy. If someone doesn't really care about that then it is unlikely they really pay that much attention to the sound. After all, critical listening is in the details.
    In regard to the coil making a difference if the wire were bare, well that's true, but if the wire were bare then there would be no sound since the +/- are shorted together. As was mentioned earlier, the shielding is what matters here.
  • Systems
    edited July 2013
    BlueFox wrote: »
    The wires don't even have to be bare to make a decent "inductor", they only have to be "separate" wires.
    Otherwise, in this instance, you have alot of cancellation with power applied at least, as speaker cable.
    Take the separate wires, and wrap them around a "core", air, plastic, iron core, equally spaced, and you have an inductor.
    Testing
    Testing
    Testing
  • Systems
    edited July 2013
    Personally, I have never seen an "uninsulated" inductor.:redface:
    Most have enamel insulation IE:"magnet wire".
    "magnet wire" which makes for a damn fine interconnect I might add!:cheesygrin:
    Testing
    Testing
    Testing
  • RamZet
    RamZet Posts: 792
    edited July 2013
    Not if the wires are shielded or insulated.
    B&W CM9Classé Sigma
  • Speedskater
    edited July 2013
    pepster wrote: »
    While few people are ever likely to see one, the do exist in radio transmitters.
    This huge broadcast station has one.
    WLW - A "Super" Station Tour
    http://www.oldradio.com/archives/stations/cinc/wlwpix.htm
