Watts per channel
Danny mc
Danny mc Posts: 24
edited June 2013 in Troubleshooting
How many watts per channel is enough for a 5.1 system?
Post edited by Danny mc on
  • mantis
    mantis Posts: 17,593
    edited June 2013
    Depends on room size and speakers. Usually 100 watts per channel and above will get the job done in most rooms. Very large rooms will require more power.
    Dan
  • boston1450
    boston1450 Posts: 7,758
    edited June 2013
    +1 ive had Harman Kardons & Denons and they do the job nicely with their conservative wattage..but some of the Sony & newer Pioneer & Yamaha's seem like they need to be higher wattage to do the job to bring out the quality of sound to the speakers..most speakers are rated above 100wpc and to power 5/1 100wpc definetly..do you have a preference on a certain receiver. That may help with this question ? Or are you in the market for one ? It may also help knowing what you have for speakers ?
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Danny mc
    Danny mc Posts: 24
    edited June 2013
    Thanks! I have a 15+20 room and Polk Monitor 60 series 2 r and l and Polk CS10 center and polk PSW 10 sub and Pioneer vsx820 at 100wpc
  • boston1450
    edited June 2013
    Does it seem like enough power for your speakers' are you looking for more power ? to bring out the quality of those 60's....Thats a fair size room for sure. My room was 16-24 and i was using a denon avr then i hooked a denon poa2200 to it because i had bought some SDA's
    but in that very same room i was using the HK avr with a NAD amp and it was fantastic to Paradigms
    Randy-Maine
    by David WMG
  • Speedskater
    Speedskater Posts: 495
    edited June 2013
    If you listen to train wreck movies at 115 dB SPL, then you can never have too much power. For other people 100 Watts per channel should be more than sufficient.
  • Danny mc
    Danny mc Posts: 24
    edited June 2013
    It's a great sounding system and I will upgrade at some point but living in a townhouse kind of puts a damper on more power! Lol! Thanks guys !
  • boston1450
    edited June 2013
    I did some research on your set up. That should sound nice. All have great reviews & with what it is. You should be fine. Enjoy & welcome to Polk....
    Randy-Maine
    by David WMG
  • Danny mc
    Danny mc Posts: 24
    edited June 2013
    Thanks,this is a great forum with a wealth of knowledge!! Glad I joined!
