Need advice ASAP
custopper30
custopper30 Posts: 252
edited June 2013 in Vintage Speakers
Hey there, I just found a listing for a pair of SDA2 in the minnesota area and the seller is asking $70 for them. I was wondering if that is a good deal for them, or if it is worth going lower? If so, what price should I try to get them for?
My set up is denon 1912, 3 Polk Monitors 70s (one as the center), and two monitor 50s.
Thanks,
Marc
Receiver: Denon 1912
Speakers:
Fronts: Polk Audio Monitor 70s (x2)
Rears: Polk Audio Monitor 50 (x2)
Center: Polk Audio Monitor 70
KLH Sub GFX-550
Post edited by custopper30 on
  • custopper30
    edited June 2013
    what do they normally go for??
    Speakers:
    KLH Sub GFX-550
  • custopper30
    edited June 2013
    Also, would they go well with my set up?
    Speakers:
    KLH Sub GFX-550
  • custopper30
    edited June 2013
    They are SDA2A sadly. I don't know if I should jump on them or not for $70. I mean, if someone wants these here I could buy them for you too! Just would like some more advice before I decide to buy
    Speakers:
    KLH Sub GFX-550
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2013
    For $70 why not just try them out? If you don't like them you could easily flip...
  • Thorton
    Thorton Posts: 1,324
    edited June 2013
    +1. I agree. Unless when you go see them it looks like his dog has been gnawing on them for years.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • custopper30
    edited June 2013
    flip for more or less? Just a heads up, I just bought and received 2 monitor 70s from polk audio direct from ebay and they came damaged though =/ waiting to hear back what is going to happen.
    Speakers:
    KLH Sub GFX-550
  • AsSiMiLaTeD
    edited June 2013
    You should be able to get the same or more than what you paid, it's only $70 though so even worst case can't be that bad.
  • custopper30
    edited June 2013
    True, I guess the only thing has me hesitant is that 1. Im a college student 2. I just bought 2 monitor 70s from polk 3. I already had one monitor 70 and 2 monitor 50.
    I might go for them, but he doesn't have a receiver to test them with... soooo ya.. also, how much is that rebuild going to cost generally?
    Speakers:
    KLH Sub GFX-550
  • Thorton
    edited June 2013
    Bring speaker wire and your receiver to him to try them out.
    DAC: Bricasti M1SE
  • custopper30
    edited June 2013
    Ya I could do that. That is what I was thinking of doing but wasn't sure if it was worth taking a risk.
    Speakers:
    KLH Sub GFX-550
  • pglbook
    pglbook Posts: 2,228
    edited June 2013
    $70 for any SDA model is a great price and a no brainer. Go for it and grab them asap! You will not be sorry. SDA is another whole world of sound!
  • pglbook
    edited June 2013
    One thing to keep in mind is that the SDA 2A are 4 ohm speakers so you will need a receiver/amp capable of running 4 ohm speakers.
    But, run and get them now and worry about anything else later. $70 is a steal for any SDA speakers!
  • westmassguy
    westmassguy Posts: 6,850
    edited June 2013
    Thorton wrote: »
    Also pull the grills, and check all the drivers carefully. All woofers should move in and out freely with no rubbing. Check the rubber surrounds for cracks or tears. Same goes for the PR, make sure it moves freely, and there are no cracks or separations. Check the bottoms for water or moisture damage. For $70.00 I'd be out the door already, if they were near me.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • custopper30
    edited June 2013
    I am just about to pick these up, but having second thoughts now only because the seller is being very fishy about what he is saying about them.
    Speakers:
    KLH Sub GFX-550
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited June 2013
    Can't hurt to check them out. If you don't like them, you can always walk away. But for $70, and if they're in good shape, that's a heck of a deal.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • ROHfan
    ROHfan Posts: 1,014
    edited June 2013
    anonymouse wrote: »
    You should read up more on SDA's if you want to integrate them into your HT setup. They are primarily a 2 channel listening system.
    I do not agree. My HT never sounded better as when I added 2As as fronts in my 7.2 system.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • westmassguy
    edited June 2013
    ROHfan wrote: »
    Can't argue with you there :) 2As make awesome fronts
  • pglbook
    edited June 2013
    custopper, did you get them? I hope so.
  • custopper30
    edited June 2013
    I have yet to go get them. The seller is being very difficult and doesn't have a receiver to hook up but wants to meet in a public place, so even bringing my own receiver doesn't seem possible.
    Speakers:
    KLH Sub GFX-550
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    If you have an Ohm meter you could at least look at the terminal readings to get a very basic idea of what kind of electrical shape they are in. You can also slowly depress each of the drivers to make sure the cones will move and there is no scratchiness in the voice coils
    Two Channel
  • custopper30
    edited June 2013
    True, but I don't have a reader and I don't really have the money to redo the speakers right now either. What is the cost to redo them though?
    Speakers:
    KLH Sub GFX-550
  • pglbook
    edited June 2013
    I know it's a tough call buying speakers without being able to hear hear them first as you have to gauge whether you can trust the Seller or not. I have done so and have been lucky so far but I always ask lots of questions and get an idea of who I am dealing with first. But, for $70, personally I think it would be worth the risk. It is at least worth going and taking a look at them in person and seeing what kind of shape they are in.
  • custopper30
    edited June 2013
    No luck getting them today, seller didn't have anytime to meet up. Hopefully tomorrow.
    Speakers:
    KLH Sub GFX-550
  • PolkieMan
    PolkieMan Posts: 2,446
    edited June 2013
    First Send back the damaged monitor 70's then...
    Man $70 is nothing... nothing even if they are a little bruised up.
    You can flip them for twice that easy unless they are bad .
    Seller is probably irradiated because he got them real cheap and wants
    to unload them fast.
    It's like free puppies do you want them or not, don't waste my time :cheesygrin:
  • custopper30
    edited June 2013
    I know people have said to push the cone and see how freely it moves in and out. Besides that, the only other thing I will be able to test is looking at the product itself and seeing any damage with my eyes. That is because the seller doesn't have a receiver to hook up the speakers to if I went to his house and he also wants to meet in a public place, which is hard to find an outlet in a public outdoor place. Which if there was an outlet, I would bring my receiver and speaker cable for it.
    Now it is time to place the IF game.
    1. If the speakers are a little dinged up, I'm assuming $70 is still a fair price?
    2. If the speakers scratch/scrap when moving in and out, what price is a fair price or even is it worth purchasing?
    Speakers:
    KLH Sub GFX-550
  • custopper30
    edited June 2013
    Oh and since they are 4 ohm speakers and my receiver is a 8 ohms rating, could I just wire the speakers in parallel and it would be rated at 8 ohms?
    Speakers:
    KLH Sub GFX-550
  • zane77
    zane77 Posts: 1,696
    edited June 2013
    If you wire anything in parallel it will drop the resistance not increase it
    Two Channel
  • custopper30
    edited June 2013
    Whoops I meant wiring it in series
    Speakers:
    KLH Sub GFX-550
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2013
    Two 4-ohm speakers in parallel = 2 Ohms resistance. Think about putting two water pipes in parallel to pass the same amount of water, less resistance.
    You will need a 4-Ohm capable amplifier. You will fry your receiver with 4 Ohm speakers.
    And as for series wiring.... What do you want to do - wire them in series to a single channel? You might as well get 4 speakers then... Just get a proper amp.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • custopper30
    edited June 2013
    Well it is the SDA2A that is rated at 4 ohms but I wanted to test them out at home but I only have a 8ohm receiver.
    Speakers:
    KLH Sub GFX-550
