My listening room
specd_out
specd_out Posts: 505
edited July 2013 in 2 Channel Audio
I decided to use one of my extra bedrooms for my listening room/wifes gaming area. Its a basic setup that is almost complete. The tv will be mounted on the wall, I may or may not get this equipment shelf http://www.bestbuy.com/site/Whalen+Furniture+-+Audio+Tower/9886557.p?id=1218194306982&skuId=9886557&st=audio%20rack&cp=1&lp=9#tab=overview to replace the tv stand, and I will be getting the ikea ponag chair http://www.ikea.com/us/en/catalog/products/S19903928/#/S79903930
I hooked it all up and after a few adjustments It sounds good. I think I will need to make some acoustic panels. certain frequencies have odd effects in the room. It can get uncomfortable to listen to. I found out quickly that having the speakers near the back wall greatly inflates the midrange and makes everything sound muffled. If you have any ideas on where to start with placing panels let me know. I am researching the subject currently.
I am really happy with the way it came out. Looks better then I thought it would.
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
Post edited by specd_out on
  • chumlie
    chumlie Posts: 8,658
    edited February 2013
    Congrats !!! Enjoy your new room.
  • ViperZ
    ViperZ Posts: 2,046
    Definitely need at least 4 panels - one behind each speaker, and one at the first reflection point for each speaker.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    Clipdat Posts: 12,962
    I'm sorry, you lost me at "wife's gaming area" - please, go on! :smile:
  • organ
    organ Posts: 4,969
    Sweet set up man. I also have the LSi9 but in cherry. After seeing pics like yours of the ebony, I'm beginning to think I should have went for that color.
    Have you tried corner loading the subs?
  • outlander
    outlander Posts: 218
    The room looks great, if you want to keep the room to yourself for serious listening, lose the TV. I have a dedicated listening room with no TV and nobody goes in that room but me because they sure don’t want to just sit and listen to music.
    O
  • brianle
    brianle Posts: 572
    Congrats in your new room. Enjoy!
  • wkjeffers
    wkjeffers Posts: 139
    check out GIK acoustics, they are affordable and can provide friendly advice if you call them. for $50 per panel, you can spend more time listening and less time stapling.
  • pablo_rodz
    pablo_rodz Posts: 331
    ViperZ wrote: »
    By 1st reflection point, do you mean on the walls next to the speakers?
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • Mikey081057
    Mikey081057 Posts: 7,127
    nice room
    enjoy
    Garage | Polk Monitor 5B's
  • specd_out
    Clipdat wrote: »
    Yea she plays COD and battlefield with me online
    organ wrote: »
    They actually are not ebony. I removed the sides for re-staining. They are naked at the moment
    No but after the success of doing that in my HT rig I have considered it for this room
    outlander wrote: »
    O
    I would but my wife needs a gaming area, and I enjoy bluray concerts, so I use the tv to watch those as well.
    DSkip wrote: »
    Essentially, yes. Go to GIK acoustics and read through some of their articles. They do a really good job explaining what you are looking for when adding room treatments.
    Thanks for the info. I will check them out
  • PSOVLSK
    PSOVLSK Posts: 5,220
    First reflection point will be tough with the window. I have that problem in my 2-channel room.
    Also, either you have too much toe-in or I don't have enough. Since no one else has mentioned anything, I'm leaning towards I don't have enough. But I guess if yours sounds good to you and mine sounds good to me it doesn't really matter.
    Nice set-up. Enjoy!
  • ViperZ
    ViperZ Posts: 2,046
    PSOVLSK wrote: »
    Nice set-up. Enjoy!
    Can always use a stand-based 'portable' panel in front of the window or hang it with the curtains :)
    Too much toe-in will most likely zero-in on a single listening chair (sweet spot)
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • RamZet
    RamZet Posts: 792
    Very cool. Im debating about adding a TV to my listening room.
    B&W CM9Classé Sigma
  • marvda1
    marvda1 Posts: 4,904
    just sit back, close your eyes and sip on some wild turkey, you don't need a tv:lol:
    Puritan PSM156
  • ken brydson
    ken brydson Posts: 8,779
    marvda1 wrote: »
    ^ This, don't know about wild turkey though... Just beverage of choice would be my suggestion^
  • recoveryone
    recoveryone Posts: 901
    I'm new here, but some quick observation I would say the room is only about a 10 x 12 maybe? if that is the case or smaller, I would remove one of the subs. That is what is causing the extra mid range and muffled sound. Subs support those mid to low Hz ranges that can be taken as the fronts are two close to rear wall or making the sound seem uneven. The ideal is to have your speakers set evenly across the front stage so each speaker will reach the listener at the same time. Another way to combat this is use the speaker distance guide to help reduce or enhance each speakers presance within the setup. I see you have the Pioneer VSX 91TX series that comes with the auto EQ mic setup. I would run that and see if it can adjust those levels for you, then if you still have those sound issues remove one one of the subs and do the same with the mic setup.
    Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
  • Inspector 24
    Inspector 24 Posts: 1,308
    Spiked speaker stands?
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • specd_out
    I got rid of the muddy mid range when I pulled the speakers away from the wall. I will kill one of the subs and see what I get though. I my vsx is in my ht setup. My 2channel is a carver pre and amp
    Yes Inspector the stands are spiked
  • recoveryone
    Looking forward to hear your results
  • xftman
    xftman Posts: 153
    Lucky you!!! I have a similar my size extra bed room I would like to 2 channels music room. But my wife wants to keep as guest room which 99% of time unoccupied and ask me to renovate my unfinished basement.
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • specd_out
    Man if I had a basement i would be all over that.
  • michael1947
    michael1947 Posts: 775
    Nice room and a great looking chair. Did you get one?
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • specd_out
    Not yet. Acoustic panels are first on my list. I am picking up the supplies for them today. The acoustics in this room suck. I dont enjoy listening in there right now. Thus the reason for my rush on building the panels
  • specd_out
    Just wanted to update this with some more progress. I am building 8 2x3x4 acoustic panels. Four of the panels will be bass traps placed across the two front corners. They will go nearly floor to ceiling. Two will be for first reflections and two will be hung in the rear of the room. Today I got all the frames built and tomorrow I will be sanding the rough edges.
    I ordered the Roxul Safe and Sound batts, and I am hoping they come in soon. My wife picked out some fabric. She said it will complement the color we plan on painting the room. I dunno though. I have my doubts. I also found two posters I plan on framing.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Heck yea man I have that rat pack poster framed above my bar.
  • headrott
    headrott Posts: 5,496
    "Eeee-Oh-Eleven.":cheesygrin:
  • specd_out
    edited March 2013
    UPDATE:
    I finished all the wall treatments. I have floor to ceiling bass traps, and 4 acoustic panels. Two on the first reflection points and two behind the chair.
    I used roxul safe and sound which is 4'x8'x3". Framed it and wrapped it in fabric. Total cost for all materials was just under $130 for 8 panels.
    The results where amazing. Every issue I was having has been fixed. Imaging has improved. Instruments are more discernible and its easier to find their location. The bass was the biggest change. That room seemed like a giant bass void. I had to have the subs maxed to get it where I liked it. As soon as the panels went up I had to turn the subs down to just below half.
    I am very happy. I would advise everyone who can to do this before upgrading anything else. It is the biggest bang for the buck improvement I have found so far.
    Also if you plan on doing this DL the Joann's app. They always have coupons for 40% or 50% off material.
    This is how I hung the panels on the door and the closet
    My favorite part. My Ikea chair. So comfortable and stylish. I love this thing
  • organ
    organ Posts: 4,969
    edited March 2013
    Nice:razz:. I like the design on the fabric you used.
  • specd_out
    edited March 2013
    Thanks. That was my wifes choice. I was really unsure of the material when we got it. It looks much better on the panel then I thought it would. Once the room gets painted it will match a little better
  • specd_out
    edited May 2013
    I did a few changes. Painted the walls a brownish grey with a darker accent wall (facing wall) Brought my PC into the room and use it for media server. Tv dubs as a bluray screen and a PC monitor.
    Changing out the light bulbs in the ceiling fan to a dimmer/warmer bulb and painting the walls the muted colors makes the room much more relaxing and creates a sort of ambiance.
    In the next month or so I am looking at getting an AQ dragonfly and a AQ 3.5mm to Rca interconnect. Looking forward to seeing the improvement gained from that.
    Both my Lsi's and King Cobras have broken in, and to my surprise I can tell a noticeable difference. I really didnt expect it but things have gotten much warmer sounding and brass instruments seem to have more detail and are less harsh overall.
    I am extremely happy with the sound I am getting from my system. Building this room has shown me that without a doubt everything makes a difference positive or negative no matter how small the change. For example the seat I sit in has a leather headrest, which sits right behind my ears. I was getting annoying reflections off the leather. I got some black dish towels, wrapped them around the edges of the headrest, and the problem was solved. Room treatments was by far the best $100 I have spent on audio sofar.
    Here are some images I took with the gopro fisheye.
