LsiM ohms
Stilly74
Stilly74 Posts: 194
edited November 2012 in Speakers
Just a heads up, I've spoke with Polk on the LsiM speaker line and they have confirmed that they can be run at 4 or 8 ohms.
So let those babies sing at 4 ohms.
    F1nut Posts: 52,365
    What are you talking about?
  • leroyjr1
    leroyjr1 Posts: 8,785
    Stilly74 wrote: »
    What?
  • lllliiioor
    lllliiioor Posts: 6
  • Stilly74
    Stilly74 Posts: 194
    My receiver has pre-outs which are connected to a 5 x 200 watt dedicated amp @ 8 ohms. My receiver can be switched from 4 ohms to 8 ohms. My amps specs are 200 watts @ 8ohms and 300 watts @ 4 ohms.
    So running my receiver at 4 ohms setting will allow the amp to push an additional 100 watts on each channel. Correct? So should help with making the sound a little more dramatic at lower volumes.
    txcoastal1 Posts: 13,520
    No...they are 8ohm speakers so set your switch to 8ohms...and in less you run them at ear damaging volumes you will probably never draw the full 200 watts.
    Seen these LSiM towers run beautifully on single ended 12 watt amps at well above reference levels
  • Stilly74
    Stilly74 Posts: 194
    txcoastal1 wrote: »
    They can be run at 4 ohms or 8 ohms. Got that direct from the horses mouth(Polk)This is what he sent back to me on my question to him.
    "That will work exactly like you said. Those speakers will be fine at that power and that setting.(4 ohms) It should sound great too!"
    Matthew Heinecke
    Customer Service Specialist
    Technical Support
  • Stilly74
    Stilly74 Posts: 194
    Stilly74 wrote: »
    This was my question to Polk in earlier email. Answer is above in earlier reply.
  • nwohlford
    nwohlford Posts: 700
    Stilly74 wrote: »
    Matthew Heinecke
    Technical Support
    The 4 ohm switch on the receiver is usually just to protect the receiver when using true 4 ohm speakers. The setting does not change the impedance of the speakers.
  • Tbone289
    Tbone289 Posts: 661
    The output of the amp is dependent on the actual impedance of the speaker, not the position of the switch.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Stilly74
    Stilly74 Posts: 194
    nwohlford wrote: »
    Not a switch but a setting in the amp menu.
    Why would they state it in the amp specs( 300 watts @ 4 ohms--200 @ 8) if you could never use it?
  • zingo
    zingo Posts: 11,258
    nwohlford wrote: »
    Best answer yet; the speakers will provide a specific load on the receiver independent of any available settings. Now if your amp used multiple output taps off an autotransformer, that would be different.
    Because eight ohm speakers will place an amplifier designed for four ohms under a heavier load, the system will play at a lower maximum volume than if four ohm speakers were used. This is due to the fact that the audio amplifier designed for four ohms can supply more power to a four ohm load than to an eight ohm load.
    F1nut Posts: 52,365
    Stilly74 wrote: »
    LOL.....no dude, that's not how it works.
    The 4 ohm setting on your AVR limits current and power to protect the AVR from damage when driving 4 ohm speakers. When using an external power amp, selecting the 4 or 8 ohm setting on the AVR doesn't do a damn thing.
  • Stilly74
    Stilly74 Posts: 194
    Funny I guess the technical support guy at Polk doesn't know what he's talking about then. Guess they just make the speakers.
    AAhhh F1 missed the AVR/Amp question....good eyes
    Thought he was talking amp output switch
    F1nut Posts: 52,365
    Stilly74 wrote: »
    In this case, he doesn't.
    Stilly....dude, once you use the preouts on the receiver the receivers amps are no longer used. So doesn't matter where that switch is set, your using an external amp buddy. The amp itself doesn't just blow out it's full rated power all the time either. Get your read on my man.
    Maybe the Polk guy just misunderstood you.....or the janitor picked up the phone.
  • Stilly74
    Stilly74 Posts: 194
    mantis wrote: »
    I think you need to learn the basics. Start with Ohms Law , learn about Ohm loads and what they mean. Then go learn about speakers , how they work . Same with Amps , how they are made , how they work , the different types of amps.
    Oh sorry there Mr stereo man. You must be so smart.. Get over yourself there guy. If would have read the post you would see I'm simply repeating/posting my conversation with tech support at Polk.
    It's guys like you on here that drive me nuts and make this site less than helpful sometimes.
    Stilly you are taking Mantis all wrong, he's serious about getting your learn on. This is a new hobby and addiction for myself, and the list he is posting are the basics. Get your google on, ask some questions, and read through the forums and be enlightened.
    I am an integrator and use resisters, diodes, etc daily...but still learning about how it applies to audio
    have fun with it
  • snake1
    snake1 Posts: 567
    Stilly74 wrote: »
    He's not trying to be a **** about it! He's just giving you some pointers on what topics to search for first. I looked up many of the same things and while its a good deal of reading, I now have a basic understanding and have helped others since then. I do understand how this can get frustrating though, but with time, effort, and a LOT of threads it starts making sense!
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • skrol
    skrol Posts: 3,488
    Stilly74 wrote: »
    Perhaps he does... He said "Those speakers will be fine at that power and that setting.(4 ohms) It should sound great too!", and he is correct. The switch won't do anything unless you are driving the speakers with the AVR but in your configuration AVR/Amp he is correct.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Inspector 24
    Inspector 24 Posts: 1,308
    txcoastal1 wrote: »
    More info on this amp?!
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    http://www.polkaudio.com/forums/showthread.php?128877-LSAF-Lone-Star-Audio-Fest-2012-May-4-6/page3&highlight=lsaf
    Post 63 LSAF- Unison Research "Little Italy" 12 watt running the LSiM705. There is a Unison S6 35 watt in the for sale section
    http://www.polkaudio.com/forums/showthread.php?137649-Unison-Research-S6-int-tube-amp-(current-version)
  • Inspector 24
    Cool, Thanks!!
    Up
    Down
  • sponger
    sponger Posts: 325
    Stilly74 wrote: »
    The technical support guy was probably trying to avoid hurting your feelings. He wanted you to feel as though you had made the right decision. I think it's part of the new "heart" marketing theme that Polk Audio has recently adopted. It's about providing quality products and service while at the same making customers feel good about themselves.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
