Popping from my Lsi9s
LaNcE
LaNcE Posts: 5
edited December 2003 in Troubleshooting
I just watched a movie on my new setup. The movie was sounding good until there was the scene where the fish were in the mouth of the whale. THis scene had a lot of deep base. I started to notice some popping coming from the rear channels (Lsi9). The receiver I am using is a Denon AVR-5803. The volume was set to -20 db. I don't have my subwoofer yet, so the speakers are set to full range. Could I possibly be overpowering these speakers? I know the Lsi9's are rated for 200 watts @ 4 ohms. The 5803 produces 170 @ 8 ohms and 200 @ 6 ohms. But they don't indicate the power @ 4 ohms. THX ultra 2 spec and the manual indicate that they can power 4 ohm speakers. Does anyone have any suggestions?
Post edited by LaNcE on
    F1nut Posts: 50,837
    edited November 2003
    Set it for small, turn it down and buy that sub for "BASS". It would seem that you bottomed out the drivers, if you're lucky you didn't damage them permanently.
  • LaNcE
    LaNcE Posts: 5
    What is the best way I can tell if there is permanent damage?
  • LaNcE
    LaNcE Posts: 5
    Oh. By the way I was going to say the movie was, "Finding Nemo" FYI for anyone who is interested. (That scene has some deep base)
    F1nut Posts: 50,837
    Just play them at normal levels, if they sound ok, you're probably alright. Just one other thing, when you talking audio or musical instruments it's BASS, not base. Base is something like the base of a pole or the base of a mountain.
  • LaNcE
    LaNcE Posts: 5
    Sorry. I know that. I'm half asleep right now. It's hard to keep my eyes open. I guess I made a typo. (I can't believe I did it twice.) :o
    F1nut Posts: 50,837
    BTW, Welcome to the forum!
  • LaNcE
    LaNcE Posts: 5
    Thanks.
    The strange thing about this whole situation is that -20 db under thx reference levels is not that loud. But I assume since this scene has some very low 'bass' (can I get it right this time?) the power output of the receiver probably jumps up closer to its dynamic peak of ~300 watts. @ 4ohms. Does this make sense? I'm just wondering when I do get my sub will I be able to keep the volumes closer to the THX levels. I personally think that 0 db in the standard is overly loud, but -20db is a good range for a close to theatre reproduction in a smaller area. Afterall if I wanted to just listen to low volumes I could just use my tv speakers. Albeit a non surround experience. What are your thoughts.
  • Frank Z
    Frank Z Posts: 5,860
    The issue here is not just the volume you were at but also the frequencies that were being sent to the speaker it self. My LsiFX's and 7's will do the same thing as your 9's if I hit them with a full range signal at a slightly elevated volume. F1 nailed it for ya, set those speakers to small and you'll be fine. The 9's are not a full range (20-20khz) speaker.
    Once you add a sub you'll be able to to play your system at volumes that will make your ears bleed. The Lsi9's will be able to perform much better if they are not trying to handle the lower frequencies.
  • mantis
    mantis Posts: 17,208
    With a nice system like that you should buy a sub right away.Use a hi quality sub to match your system
    Dan
  • scottvamp
    scottvamp Posts: 3,277
    Awesome setup Lance - buy a quality sub like the rest of your system and set to SMALL.
  • Jeffrey_B
    Jeffrey_B Posts: 21
    Ditto. I have the LSiC, FX, and 9's and an SVS 20-39 PC+ sub. Set your speakers to SMALL and let the sub do the work. Then, the LSi's will sound great! JEFF
  • Dr. Spec
    Dr. Spec Posts: 3,780
    This just goes to show you how DVDs are all mixed differently.
    Some DVDs only use the LFE channel for strong bass.
    Other DVDs use ALL channels for full range signals. Like U-571 and (apparently) Finding Nemo - which BTW has brutally strong and aggressive bass.
    Those of us with subs and surrounds set to small don't know the difference (and don't really care).
    But those of us running large on all channels will get a rude awakening when a brute like the 5803 sends a full range high amplitude bass signal to the rear surround channels and you are running a speaker like the LSi9.
    A good sub, small, and 80 Hz will fix you up straight away, and will also improve the overall sound of the system.
    SVS
  • scottvamp
    Where did Lance go???????????
    Buying a quality sub I hope............;)
    Lesson one
    *Set Speakers to small
    *Buy a quality subwoofer;)
  • stevecramer2
    stevecramer2 Posts: 34
    I have a Pioneer Elite VSX-55TXi (receiver). I think I understand the concept of the Large/Small settings in speaker bass response.
    But moving this idea from the page to my setup is difficult. Don't really know which switch, button or knob to turn to get the 'Large - Small' setting?
    Help, help!
    SC2
    Decoding:
    Dual Motorola 150 MIP / 48-Bit DSP Engine
    DTS-ES Discrete 6.1
    DTS NEO 6: Music & Movie
    DTS 96/24
    Dolby Digital-EX
    Dolby Pro Logic II Music & Movie
    Processing:
    Super Audio CD (SACD) Direct Mode
    Hi-Bit Audio Scaler converts digital sources to 96kHz/24-Bit Resolution
    96kHz/24-Bit A/D Conversion (2 Ch.)
    192kHz/24-Bit DAC
    Auto MCACC (Multi-Channel Acoustic Calibration) with Microphone
    Air Studios Sound Tuning
    Front Speaker all Alignment
    Manual EQ Adjust (5-band x 7)
    THX Select Post Processing
    7-D Theater
    7 Channel Stereo
    6 Cinema Modes
    6 Concert Modes
    Digital Noise Reduction
    Midnight Mode
    Multi-Channel Multi-Band EQ
    Loudness
    Power:
    THX Select Certification /Air Studios Sound Tuning
    Advanced Direct Energy MOS FET Amplification
    Wide Band Frequency Response (5Hz -100kHz)
    100 watts x 2 Stereo
    100 Watts x 7 Multi-Channel
    Component Video On-Screen Display
    Front Panel Jog Control for all On-Screen Menu Functions
    Function Rename
    30 Tuner Preset
    Command Macro
    MR/MS w/ Front Panel Control
    Surround Back to MR/MS Amplifier Re-Configuration
    12v Trigger
    Illuminated Smart LCD Remote
    DVD, DSS, DTV, Multi-CD Control
  • polkatese
    polkatese Posts: 6,767
    Steve,
    not knowing your receiver, I would venture it's in the setup On Screen Display menu, under speaker setup. Good luck!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
