Recommended Speaker Wire
vositis
vositis Posts: 2
edited September 2012 in Speakers
For runs of 30', what guage/type of speaker wire should I be using? Does it really make a big difference?
-VO
  • nhhiep
    nhhiep Posts: 877
    another wire thread? check out monoprice.com
  • mantis
    mantis Posts: 17,647
    Audioquest Flx 14-2 for just about any speakers and amp combos at 30 foot runs.
    Dan
  • decal
    decal Posts: 3,205
    It must cost at least $250.00 per foot to be any good.
  • Obsession18
    Obsession18 Posts: 191
    For a run that long the heavier the guage the better, check out Blue Jeans Cable, the Canare 4S11 at $1.35 a foot is some good stuff.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • Outfitter03
    Outfitter03 Posts: 563
    If you want to do DIY cables this is a good source for the Canare 4S11. A lot of bang for the buck.
    http://www.performanceaudio.com/buy/Canare/4S11/535
  • Upstatemax
    Upstatemax Posts: 2,854
    +1
    Just ran a friends whole system in this. He was using monprice before and he loves this new wire.
    EndersShadow Posts: 17,752
    mantis wrote: »
    I used 14/4 for my front three for a bit. Not bad at .75c per foot. I got out of there for 33 dollars for 33 feet of wire.
  • pploeser
    pploeser Posts: 88
    +1 - great wire for the price.
  • ravaneli
    ravaneli Posts: 530
    monoprice is good enough but the gauge is important for long runs. It depends on the power of the speakers that you will run. They have these charts that recommend gauge for power over particular lenght..
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • dracoskeeper
    dracoskeeper Posts: 142
    + 1 on Blue Jeans Cable
  • leftwinger57
    leftwinger57 Posts: 2,917
    Even I'm getting tired of this one.30' per run is getting up there. I would go w/ a no brand 14 gauge.But if you must have a name behind it and not rip your wallet apart Blue Jeans,Monoprice,Parts Express will help you out.
  • Doc99
    Doc99 Posts: 100
    Check out KnuKoncepts. They have some nice quality cable there that is affordable.
