Amp for LSiM 707
chris23120
chris23120 Posts: 95
edited April 2013 in 2 Channel Audio
I have been reading a lot about these LSiM 707's and am getting ready to buy a set for 2 channel use. What would a good amp in the $2500 or less price range be to power these? Thanks.
Samsung UN55C6500 55" LED
Onkyo TX-NR3007
Polk Audio RT5000
-RT3000 front
-CS1000 center
-FX1000 dipole
Polk Audio PSW1000 5.1 sub
Polk Audio microPRO 4000 x2 5.2 subs:biggrin:
Post edited by chris23120 on
  • Face
    Face Posts: 14,340
    edited September 2012
  • falconcry72
    falconcry72 Posts: 3,580
    I love the LSiM's. I've never heard the towers, but the 703's are excellent, and they definitely need to good electronics to let you hear what they're capable of.
    Your budget will allow for a vast number of great amps. Are you looking to buy new or used? That's a big first consideration.
    What will make up the rest of this 2-channel setup? Depending on what you have/what you have in mind, some of that money may be better spent elsewhere in the system.
    Congrats on deciding to go LSiM! You'll be very happy!:biggrin:
  • parimento1
    parimento1 Posts: 15
    You may even try biamping them as they are very power hungry and may benefit from that.
    nooshinjohn Posts: 26,000
    Parasound and Sunfire signature amps sounded superb on these speakers. The Sunfire's can be had well within budget and the Parasound is a bit more expensive but still within range.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Running a parasound halo amp on my lsim's and they sound great.
  • cstmar01
    cstmar01 Posts: 4,424
    Tons of amps in the 2500 range. Comes down to also what pre are you mating it with etc. tell us some more about the sound you like and what else is being paired with it.
  • Tankman
    Tankman Posts: 419
    Check out a BK Butler Amp.
  • marvda1
    marvda1 Posts: 4,963
    Puritan PSM156
  • polkrt3000p
    polkrt3000p Posts: 145
    edited October 2012
    Love sunfire stuff, but Adcoms always had a place in my house. It may not be the best, but you will need to blow a lot of coin to beat it, just my opinion.
    Toolfan66 Posts: 18,184
    edited October 2012
    A set of SX-1000 monos from W4S would fit the bill nicely...
    F1nut Posts: 51,997
    edited October 2012
    A few solid suggestions all under your budget and available right now.
    BAT VK-200, VK-220 or VK-500
    Bel Canto Design Evo200.2 monoblocks
    I've heard the 707's on Bel Canto, a perfect match.
    Consider this integrated as well.
    Plinus 9200
  • mantis
    mantis Posts: 17,559
    edited October 2012
    I ran the LSim703's off a few different things but when I connected them to our Bryston system , magic came to mind many times.
    I saw this amp over on the gon , I suggest checking it out. I'd buy it in a heartbeat.
    http://app.audiogon.com/listings/solid-state-bryston-4b-sst-black-2012-10-05-amplifiers-44721-canton-oh
    Dan
  • DAlba
    DAlba Posts: 124
    edited February 2013
    I will be getting a complete LSiM surround system with the 707's upfront. Any recommendations on a 7ch amp under $3000?
  • Face
    Face Posts: 14,340
    I use the 5 channel version for my HT. http://www.wyred4sound.com/webapps/p/74030/117839/339145
  • RamZet
    RamZet Posts: 792
    check out the B&K Reference 200.7
    200w x7 and I think it will run you about $2600 new.
    http://www.bkcomp.com/products/amplifiers/?tx_ttproducts_pi1%5BbackPID%5D=14&tx_ttproducts_pi1%5Bproduct%5D=10&cHash=f7aaf13d9a
    B&W CM9Classé Sigma
  • Habanero Monk
    Habanero Monk Posts: 715
    ATI has some multi-channel offerings. From what an Audioholics member posted the ATI 3000 series is the Mark Levinson 532H.
    I guess they are under $3K if used is an option. Emotiva has some new amps out as well. Although you may need dedicated power outlet by the looks of them:eek:
  • pearsall001
    pearsall001 Posts: 5,327
    I'm running a pair of d-Sonic M2-600M monoblocks with my KEF Q900's...I can't say enough good things about them. Highly recommended. Well within your budget.
    http://www.d-sonic.net/
  • RamZet
    RamZet Posts: 792
    Looking at all the amps everybody has listed and I must say this isn't going to make it easy. These are all awesome Amps. Good Luck!
    B&W CM9Classé Sigma
  • chris23120
    edited April 2013
    Agreed. When I get to 100 posts I will start looking to see what is in the classifieds...
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
    F1nut Posts: 51,997
    edited April 2013
    No, he meant the amps listed above in this thread. I took a quick look in the FM for you and there's nothing right now.
  • [Deleted User]
    [Deleted User] Posts: 1,394
    edited April 2013
    chris23120 wrote: »
    Dust in the closet....kidding. It's a hoax, there is no classified section here. Don't know who told you, but I am sure it was a joke.
    txcoastal1 Posts: 13,519
    edited April 2013
    halenhoang wrote: »
    And your Usher's were just a dream....:lol:
  • ken brydson
    ken brydson Posts: 9,022
    edited April 2013
    Hello...echo, echo. Nope, nothing to see here...
  • [Deleted User]
    edited April 2013
    Hehe. Was just having some Friday fun. There are tons of amps out there under that price range. Since you are going for home theater, get an emotiva amp. Ice amps or class d, the ones in receivers, simply can't touch the bang of emotiva.
    There, my Friday night suddenly became multitudes better.
  • chris23120
    edited April 2013
    Thanks for checking.
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
  • ken brydson
    edited April 2013
    chris23120 wrote: »
    1 more usless post. 26 to go...
  • chris23120
    edited April 2013
    25 to go...
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
  • jumpindick
    jumpindick Posts: 428
    edited April 2013
    look at parasound halo series as well. Can't say about any other brand since I have no experience with them, but halo A21 is a great amp and gets me what I wanted.
