B&K AVR-505/507 or Rotel Seperates?
rookiejk
rookiejk Posts: 60
edited October 2003 in Electronics
I am thinking of getting a AVR505 to drive my Lsi setup. Does anyone have experience with this receiver. Am I better off getting something like the 505 or Rotel seperates? These are the two paths I have considered.
Receiver: B&K AVR505
Fronts: Lsi25s
Center: Lsic
Surround: LsiXs
TV: 57'' RP Toshiba
Post edited by rookiejk on
  • mantis
    mantis Posts: 17,394
    edited October 2003
    I traveled this road and I felt B&K was the better of the 2.I feel B&K is a class and really is above Rotel.Comparing the B&K avr505 or 507 to Rotel seperates will suprise you.If you think receiver can't compete with seperates,do that demo...and be shocked.
    Rotel is a fine Product.You will even spend les with Rotel.There seperates are cheaper then B&K's receiver.B&K seperates blow the Rotel out of the water as far as price.Sound quality now gets even further away.
    Rotel is a great choice here as well.Leave B&K out of the picture and I can't think of a better company in there price class that would be a better choice.Rotel makes killer amps.There preamps are more on the basic side but simple is better most of the time.
    B&K rules for Preamps.Even the new RSP1098 doesn't hold a candle to the awesome ref50.....same price.
    But as I always say,it's up 2 you.Ask for an opnion and get one you will.Mine will always be honest and true to the gut ....feeling that is.....B&K is a better product.
    Dan
    Dan
  • rookiejk
    rookiejk Posts: 60
    edited October 2003
    So, in summation you think the B&K 505 will give me a better sound than rotel seperates. Correct? Does anyone else have an opinion on this?
    Fronts: Lsi25s
    Center: Lsic
    Surround: LsiXs
    TV: 57'' RP Toshiba
    F1nut Posts: 51,776
    edited October 2003
    I think there are other choices and you need to get out and demo as many of them as you can. Look at the following:
    Parasound HCA or even better, the Halo line
    Conrad-Johnson
    Sunfire
    Aragon
    Bryston
    B&K and Rotel make good gear, but there is better.
  • rookiejk
    rookiejk Posts: 60
    edited October 2003
    f1--
    I am limited monetarily. I suspect most of the brands you have mentioned would cost well above my limit. The reason I was trying to decide between the rotel seperates and the B&K 505 was that I can get the Rotels for like 2k and the 505 for 1700. What is my best bet in the price range under 2k, to drive the Lsis? I thought that 1700 for a barely used 505 was a pretty good deal. I appreciate any suggestions.
    Fronts: Lsi25s
    Center: Lsic
    Surround: LsiXs
    TV: 57'' RP Toshiba
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2003
    If you are using 2K as a price mark, than that drops Parasound out of the running.
    The B&K offers upgrades, and to me that is invaluable. I vote B&K.
    F1nut Posts: 51,776
    edited October 2003
    Rookie,
    Ok, price points always help. I would still suggest (if you can) to demo the two units you're interested in. Also, a great way to get more for less is buy used, look on www.audiogon.com and check out www.audioreview.com to see what others have to say.
  • mantis
    edited October 2003
    If you can get the avr505 for 1700.00.............no brainer here.Just buy and don't look back
    Thats a killer price I would buy it myself.It retails for 3500.00.
    **** slightly used better slighty broke in for you........
    Dan
  • rookiejk
    rookiejk Posts: 60
    edited October 2003
    Well, I bought the 505 and I can't wait to try it out with my Lsis. I'm sure it will sound great. I will update you everyone if you are interested.
    Fronts: Lsi25s
    Center: Lsic
    Surround: LsiXs
    TV: 57'' RP Toshiba
  • dorokusai
    edited October 2003
    Yes we are interested. Nice grab, have fun!
