SDA 2 has no sound from Stereo HF tweeters
  • drumminman
    drumminman Posts: 3,396
    edited June 2012
    Should be no fiber fill below the level of the MW's. You're right - having it down there will reduce bass response.
  • 81hotcar
    81hotcar Posts: 23
    edited June 2012
    Is there a schematic for the older original SDA 2 ? I don't see it. If I were to have someone work on the crossovers They would need that to know the value of the induction coils. A parts list as well. I will have the coils tested before going forward.
    F1nut Posts: 51,794
    edited June 2012
    Stereo Board:
    Resistors;
    2.7 ohm/5 watt
    4 ohm/5 watt
    Caps;
    (2) 750pF (silver mica)
    0.5uF (mylar)
    12uF (mylar)
    27uF
    Inductors;
    0.4mH
    1.82mH
    11.2mH
    Dimensional Board:
    Resistors;
    2.7 ohm/5 watt
    4 ohm/5 watt
    Caps;
    750pF (silver mica)
    12uF (mylar)
    27uF
    Inductors;
    0.4mH
    1.82mH
  • 81hotcar
    81hotcar Posts: 23
    edited June 2012
    Thanks F1nut the parts list will help.
