Brgman's gaskets or Mortite?
gwg_97
Anyone have experience with both? Impressions? I am currently upgrading my 1Cs and would welcome any first-hand knowledge or opinions. For some reason Mortite seems a little messy (if you know what I mean).
Thanks!
Thanks!
System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
Post edited by gwg_97 on
Brgmans gaskets hands downSpeakers: SDA-1C (most all the goodies)
I have had great success with Mortite and have found it easy to work with. BUT, if I had both sitting in front of me, I'd go with the gaskets for sure.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Good to hear. Mike was kind enough to sell me gaskets for the SWs, MWs, and tweeters. I was a little concerned that they might degrade over time. -
Thanks!
Something thats pretty easy to work with as well is called Armaflex. You can pick it up at home depot and its MUCH easier to use than Mortite and quite cheap as well.
DK did a nice write up on it v. Mortite and the stock gaskets here
I used the Armaflex for my db840 mod on my LSi 15's and it worked great!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Something thats pretty easy to work with as well is called Armaflex. You can pick it up at home depot and its MUCH easier to use than Mortite and quite cheap as well.
Thanks for the link! Great information. -
No problem man, like I said that stuff is easy to find and use. By no means am I commenting on on brgman's gaskets as I havent seen them in person or installed them.
I just know that stuff is something you could go pick up tonight and do your baskets with. Dont forget the other mod's like dynamatting the drivers"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Dont forget the other mod's like dynamatting the drivers [/QUOTE]
Oh yeah, its on the list. :cool: -
I used 1/2" closed-cell foam weather strip from Lowes on my Advents and it was very easy to use and seals very good. One side has adhesive and helps stick on the back of speaker frame.
http://www.lowes.com/pd_66679-81-02295_0__?productId=1096047&Ntt=foam+strip&Ns=p_product_price|0&pl=1¤tURL=%2Fpl__0__s%3FNtt%3Dfoam%2Bstrip%26Ns%3Dp_product_price%7C0&facetInfo=
So many options. Thanks!
The best and cheapest gasket material is the rubberised cork gasket material you can get at any automotive parts store. Depending on how thick it is you purchase it in rolls or sheets. this stuff is used for things such as enigne valve cover gaskets where is lasts for year after year. In the enviroment of a speaker gasket you will never have to address this issue again.Radio Station W7ITC
transmaster wrote: »The best and cheapest gasket material is the rubberised cork gasket material you can get at any automotive parts store. Depending on how thick it is you purchase it in rolls or sheets. this stuff is used for things such as enigne valve cover gaskets where is lasts for year after year. In the enviroment of a speaker gasket you will never have to address this issue again.
Thanks transmaster! Great idea. I just saw your sig. My grandfather used to work at Collins Radio long ago. Unfortunatly, that's all I know. I just wish I knew how to get rid of all of his NOS radios and tubes. OK, he did work for Collins Radio. I made up the part about the NOS gear. Sorry, I can be a bit of a ............ sometimes. -
This stuff doesn't have adhesive on one side though, does it? If not, I think it would be more difficult to work with for speaker gaskets. Also, does this come in rolls that are of a useable (eg. 3/8"-1/2") width, or do you need to cut it lengthwise too?
For any of these gasket/sealer products what is the ideal width we should use for 6-1/2" drivers, PRs and tweeters for say, Monitor 10Bs and SDA-2Bs?
Lastly, can someone explain what "brgman gaskets" are? -
Brgman gaskets suck!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Brgman is a Club Polk member who was selling "home made" gaskets a few months ago.
actually factory made by a gasket manufacturer for us polkiesMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Be nice. From what I can tell, Brgman is a pretty good guy.
Don't let that lie out!!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
So............Uh...........Are they more gooder than the other options available to us? :cheesygrin:
Are they still available? Any pics out there of these things? It'd be nice to have something that's pre-cut and easy to work with for our specific drivers/PRs/tweets! -
Tour2ma bought about all my extras but if he won't help we can get you fixed up.
Get some feedback from those that used them and let me know.
See who else chimes in.I'm biased.Some folks may not like them after all.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I picked up a set of brgman's gaskets for my SDA 2A's and they did a great job of sealing the cabinets.
I used brgman's gaskets and they worked really well. I have placed two different orders for them. The last order I received were a little thicker than the first. (I knew that when I ordered.) All did a good job of sealing but I found the thicker ones easier to work with.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Damn you had me going for a second If you where to have say a Collins KW-1 you would not want to give out your location because hamradio operators would be out in front of your house, shooting, knifing, running over, poisoning, and other wise killing each other to be the first to knock on your door, am only halfway kidding about that, I don't suppose they would poison each other.Radio Station W7ITC -
I have never dealt with him personally, but have read some good things about his gaskets.Testing
Testing
Testing -
President of Club Polk -
teekay0007 wrote: »This stuff doesn't have adhesive on one side though, does it? If not, I think it would be more difficult to work with for speaker gaskets. Also, does this come in rolls that are of a useable (eg. 3/8"-1/2") width, or do you need to cut it lengthwise too? For any of these gasket/sealer products what is the ideal width we should use for 6-1/2" drivers, PRs and tweeters for say, Monitor 10Bs and SDA-2Bs?
Actually what you do is cut the gasket ring out of the cork material in one piece, use a hole punch to punch out the holes for the screws. I made my hole punch out of an old 1/4 drive deep well socket, pick one that has the correct diameter and sharpen the edge. When you are finished you have a gasket that is like the original except it is made out of cork. If you want an adhesive surface you can apply that yourself. You can get rubberized cork sheets as thin as a 1/16 of an inch which is just about the thickness of the originals.
You mark out the gasket either by using the driver in question to trace it out, or use a compass scribe to mark it out on the neoprene/cork sheet. You can cut it out with a heavy set of scissors, or you can cut is out with a sharp wood chisel. If you make a template for the gasket them you can cut it out with a very sharp dry wall knife.
THICKNESSES / WIDTHS AVAILABLE FOR CORK & NEOPRENE MEDIUM
Thickness / Width
1/32" x 36" sq.
1/16" x 36" sq.
1/8" x 36" sq.
3/16" x 36" sq.
1/4" x 36" sq,
5/16" x 36" sq.
3/8" x 36" sq.
1/2" x 36" sq.Radio Station W7ITC -
Concur! Brgman gaskets. Don't look back.Too much **** to list....
Thanks again guys. I'm going to meet with a fellow Polkie today and talk crossover options. Should be fun.
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
+1000000000000000 BIG TIME.:razz:
That's why I bought enough to do both set's of my SDA's twice. With SDA's one can never have to many spare parts.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
EndersShadow wrote: »Don't forget the other mod's like dynamatting the drivers
I am in the process of refurbishing a pair or Polk Monitor 10B's the XO's have been re-cap'ed and the resistors replaced.
I am now waiting for a pair of MW-6503's to replace the bad set in one of the them. I noted the dynamat on the spiders
what does that do?Radio Station W7ITC
