PSW505 wire off woofer
brian_tr
brian_tr Posts: 3
edited March 2012 in Troubleshooting
I just bought a PSW505 subwoofer through amazon. Could not get it to work. After looking through forum found someone that had same problem and they said Polk had them check wiring to sub and wire was off. I pulled amplifier and the black wire going to the sub is off. I have big hands and arms and am unable to get wire back on. Where do I go from here?
Post edited by brian_tr on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited March 2012
    Hello,
    Welcome to Polk's forum. You can pull the woofer out of the cabinet and attach the wire. Just remove the grille cover and there should be a decorative gasket going around the outside of the woofer. Pull the gasket off and take out the screws holding the woofer onto the cabinet, sometimes you need to use a putty knife to loosen the woofer. If you contact Polk's CS they'll send you a replacement gasket.
    Regards, Ken
  • brian_tr
    brian_tr Posts: 3
    edited March 2012
    Thanks. At least I could get to the woofer. I am replacing a paradigm PDR-12. Could not find a way to get the face off that sub to replace woofer. Any how the connector was extremely loose. Would not stay on. Don't think this was a shipping problem. I think it was probably very loose on install. Crimped connector and wont come off now. Both connectors seem loose but wont come off. Will see. This was not what I was wanting to see on my first Polk speaker. All my paradigm speakers are getting old and will be looking for replacements before long. I will need to get a new gasket. Thanks again for help and quick reply.
  • [Deleted User]
    edited March 2012
    No problem, glad to be of help.
    Take care, Ken
  • Tankman
    Tankman Posts: 419
    edited March 2012
    Kenneth, You rule man! This is why i have Polk AUDIO GEAR.Great service=Happy People!:cool:
  • [Deleted User]
    edited March 2012
    Thanks, Tank, I agree completely!
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited March 2012
    So now that it's working, how do you like the 505 compared to the Paradigm??
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • brian_tr
    brian_tr Posts: 3
    edited March 2012
    I guess I need to go rent a good movie and try but so far what I have heard the Paradigm was a lot better. Wish I would of figured out how to remove woofer and replaced. I may still do it. I could not remember how to put the insulation back in the cabinet. I kind of stuffed it in the air chamber to the back. May have something to do with it.
  • Inspector 24
    edited March 2012
    Interesting...could you tell a little more about what you heard? What were you listening to?
    Up
    Down
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2012
    Glad that you got it working! For the record, my DSWPro550WI sounds better than most subs in the price range. Your PSW505 is also a good choice. Polk subs rock!
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
