Too much mid bass with LSi 9
124»
    heiney9 Posts: 25,408
    edited March 2012
    nhhiep wrote: »
    The thing is I have many monoprice 12/14AWG cables here. The Lsi9s is only $500, I rather not spend another 50+ on cables. 12AWG should be good right? Plus the distance from my AMP=>Speakers is only 3-5fts.
    No, but whatever thought process gets you through the night.
    tonyb Posts: 33,067
    edited March 2012
    nhhiep wrote: »
    Distance doesn't have a bearing unless we are talking extremes, which we aren't. Fifty bucks ? Lsi's-Rti12's, amps.....a 50 won't make a dent. Just saying is all, with some better cabling, you may get some better SQ out of those speakers. Just a suggestion is all, if you can't afford it, so be it. Keep an eye out on the used market, deals always pop up. Happy listening.
